Hi. I am stuck on an error that I get after deploying nodes. Everything appears to work fine except post installation cloudinit tasks. No matter what OS I deploy, I always get the following errors below, which prevent my ssh keys from getting added and I can’t login into any environments.
**Node post-installation failure - 'cloudinit' running config-keys-to-console with frequency once-per-instance**
**Node post-installation failure - 'cloudinit' running config-ssh-authkey-fingerprints with frequency once-per-instance**
**Node post-installation failure - 'cloudinit' running modules for final**
Thanks for the suggestion. It did not help, unfortunately, but I did get MAAS to work successfully. I found out that the deployments pass or fail based on the hardware/software it is trying to deploy. I get mixed results using the same controller. Some computers will keep restarting, Proxmox virtual machines will fail on the final cloud-init task, while others would report a missing image for Cent Os 7 error. I manged to get a working Cent OS 7 install on an old Ethereum mining machine I had. Nothing funny happened during the deployment tests. I am going to test some newer gaming boards that I have to see if this only happens with older/virtual machines.
Thanks for the suggestion. I will give that a shot.
I can confirm that my crappy hardware was the issue. I am using three gaming motherboards and I have not had any issues deploying Cent OS. Moral of this thread is don’t test on old(decade) hardware. Thanks again for the help tension.
