The following is a list of kernel tasks that you can perform with the MAAS CLI.
- What should I know about Ubuntu kernels on MAAS?
- What kernel boot options are available?
- How do I get started with the MAAS CLI?
- How do I set a minimum kernel for enlistment and commisioning?
- How to I set a minimum deploy kernel for a machine?
- How do I set a specific kernel during machine deployment?
Set a default minimum kernel for enlistment and commissioning
The command option default_min_hwe_kernel
appears to apply to only HWE kernels but this is not the case.
Set a minimum deploy kernel for a machine
Set a specific kernel during machine deployment
The operation will fail if the kernel specified by hwe_kernel
is older than the kernel (possibly) given by default_min_hwe_kernel
. Similarly, it will not work if the kernel is not available for the given distro series (such as ‘hwe-16.10’ for ‘xenial’).
The command option hwe_kernel
