CLI kernel management (snap/2.7/CLI)
The following is a list of kernel tasks that you can perform with the MAAS CLI.
Set a default minimum kernel for enlistment and commissioning
Set a minimum deploy kernel for a machine
Set a specific kernel during machine deployment
