The following is a list of kernel tasks that you can perform with the MAAS CLI.
- What should I know about Ubuntu kernels on MAAS?
- What kernel boot options are available?
- How do I get started with the MAAS CLI?
- How do I set a minimum kernel for enlistment and commisioning?
- How to I set a minimum deploy kernel for a machine?
- How do I set a specific kernel during machine deployment?
Set a default minimum kernel for enlistment and commissioning
Set a minimum deploy kernel for a machine
Set a specific kernel during machine deployment
