The following is a list of image management tasks to perform with the MAAS CLI.
- How do I get started with the MAAS CLI?
- What might I need to know about images?
- How do I list boot sources?
- How do I select images?
- How do I list image selections?
- How do I import newly-selected images?
- How do I list currently available images?
- How do I delete a boot source?
- How do I edit a boot source?
List boot sources
Select images
subarches="*" labels="*"
Hardware enablement (HWE)
subarches="hwe-x" labels="*"
List image selections
Import newly-selected images
Delete a boot source
Edit a boot source
Update the boot source:
Add a boot source
- Use a local image mirror (official images)
- If you deleted the default image, recreate it
The general syntax is:
Once the source is added, proceed to the Select and import images step.
Using a local image mirror
- URL=https://$MIRROR/maas/images/ephemeral-v3/daily/
- KEYRING_FILE=/usr/share/keyrings/ubuntu-cloudimage-keyring.gpg
- URL=https://images.maas.io/ephemeral-v3/daily/
