CLI image management (snap/2.7/CLI)
The following is a list of image management tasks to perform with the MAAS CLI.
List boot sources
Select images
    subarches="*" labels="*"
Hardware enablement (HWE)
    subarches="hwe-x" labels="*"
List image selections
Import newly-selected images
Delete a boot source
Edit a boot source
Update the boot source:
Add a boot source
The general syntax is:
Once the source is added, proceed to the Select and import images step.
Using a local image mirror
  • URL=https://$MIRROR/maas/images/ephemeral-v3/daily/
  • KEYRING_FILE=/usr/share/keyrings/ubuntu-cloudimage-keyring.gpg
  • URL=https://images.maas.io/ephemeral-v3/daily/
