CLI DHCP snippet management (snap/2.7/CLI)
This document presents a list of DHCP snippet management tasks that you can perform with the MAAS CLI.
Create a snippet
To create a global snippet:
    global_snippet=true
To create a subnet snippet:
    subnet=$SUBNET_ID
To create a node snippet:
    node=$NODE_ID
List snippets
To list a specific snippet:
Update a snippet
Update a snippet attribute:
Enable or disable a snippet
Delete a snippet
To delete a snippet:
