The web UI enables you to easily write, upload and execute your hardware testing scripts and see the results. However, the MAAS CLI supports options not available from the web UI, including access to earlier versions of your scripts, script deletion and result automation.
- How do I upload and manage test scripts?
- How do I use tags to help with test scripts?
- How do I view test results?
- What metadata fields are available to me for test scripts?
Script management
The optional filters argument lets you search for tags assigned to a script, such as using TAG=cpu
with the above example.
"history": [
"id": 40,
"comment": "Updated version"
"id": 34,
"comment": null
MAAS keeps a history of all uploaded script versions, allowing you to easily revert to a previous version using the id
of the version you wish to revert to:
To delete a script, use delete
Tags
Results
If you only want to see the latest or currently-running result, you can use current-commissioning
, current-testing
, or current-installation
instead of an id:
where $SUPPRESSED
is either True
or False
. The JSON formatted output to the above command will include ‘results’ dictionary with an entry for suppressed
"results": [
"id": 21,
"name": "smartctl-validate",
"status": 5,
"status_name": "Aborted",
"exit_status": null,
"runtime": "0:00:00",
"endtime": 1554238601.765214,
"parameters": {
"storage": {
"argument_format": "{path}",
"type": "storage",
"value": {
"id_path": "/dev/vda",
"model": "",
"name": "sda",
"physical_blockdevice_id": 1,
"serial": ""
"script_id": 1,
"script_revision_id": null,
"suppressed": true
$RUN_ID is labelled id
in the verbose result output.
