The web UI enables you to easily write, upload and execute your hardware testing scripts and see the results. However, the MAAS CLI supports options not available from the web UI, including access to earlier versions of your scripts, script deletion and result automation.
- How do I upload and manage test scripts?
- How do I use tags to help with test scripts?
- How do I view test results?
- What metadata fields are available to me for test scripts?
Script management
"history": [
"id": 40,
"comment": "Updated version"
"id": 34,
"comment": null
Tags
Results
"results": [
"id": 21,
"name": "smartctl-validate",
"status": 5,
"status_name": "Aborted",
"exit_status": null,
"runtime": "0:00:00",
"endtime": 1554238601.765214,
"parameters": {
"storage": {
"argument_format": "{path}",
"type": "storage",
"value": {
"id_path": "/dev/vda",
"model": "",
"name": "sda",
"physical_blockdevice_id": 1,
"serial": ""
"script_id": 1,
"script_revision_id": null,
"suppressed": true
