CLI commissioning and hardware testing scripts (deb/2.7/CLI)
The web UI enables you to easily write, upload and execute your hardware testing scripts and see the results. However, the MAAS CLI supports options not available from the web UI, including access to earlier versions of your scripts, script deletion and result automation.
Script management
"history": [
        "id": 40,
        "comment": "Updated version"
        "id": 34,
        "comment": null
Tags
Results
"results": [
        "id": 21,
        "name": "smartctl-validate",
        "status": 5,
        "status_name": "Aborted",
        "exit_status": null,
        "runtime": "0:00:00",
        "endtime": 1554238601.765214,
        "parameters": {
            "storage": {
                "argument_format": "{path}",
                "type": "storage",
                "value": {
                    "id_path": "/dev/vda",
                    "model": "",
                    "name": "sda",
                    "physical_blockdevice_id": 1,
                    "serial": ""
        "script_id": 1,
        "script_revision_id": null,
        "suppressed": true
