we have MAAS 3.4 in deployed running as a region+rack controller. we have used the same system to test various deployments to various machines and the postgres database files have ballooned to over 60gb, and there is no change in database size even after removing all machines, custom images, and running vacuum on the database. Is there a better way to go about this? we would simply like to reset maas to a fresh installation state.
Could you post the full output of the following query?
select
table_name,
pg_size_pretty(pg_total_relation_size(quote_ident(table_name))),
from information_schema.tables
where table_schema = 'public';
btw if you want to start from scratch why don’t you drop the db, create a new one and re-initialize MAAS?
This is of interest to me too - here is our output from that for reference.
table_name | pg_size_pretty | pg_total_relation_size
maasserver_discovery | 0 bytes | 0
django_session | 592 kB | 606208
maasserver_routable_pairs | 0 bytes | 0
maasserver_podhost | 0 bytes | 0
django_migrations | 80 kB | 81920
django_site | 56 kB | 57344
maas_support__ssh_keys__by_user | 0 bytes | 0
auth_user | 80 kB | 81920
auth_group | 24 kB | 24576
auth_permission | 160 kB | 163840
django_content_type | 40 kB | 40960
auth_user_user_permissions | 32 kB | 32768
auth_user_groups | 32 kB | 32768
maasserver_bootresource | 112 kB | 114688
maasserver_bootresourceset | 104 kB | 106496
maasserver_bootsource | 64 kB | 65536
maasserver_dnsresource | 40 kB | 40960
maasserver_fabric | 88 kB | 90112
maasserver_dnspublication | 400 kB | 409600
maasserver_dnsdata | 24 kB | 24576
maasserver_mdns | 24 kB | 24576
maasserver_neighbour | 776 kB | 794624
maasserver_globaldefault | 40 kB | 40960
maasserver_rootkey | 16 kB | 16384
maasserver_resourcepool | 64 kB | 65536
maasserver_zone | 64 kB | 65536
maasserver_vmcluster | 48 kB | 49152
maasserver_nodekey | 160 kB | 163840
maasserver_virtualblockdevice | 96 kB | 98304
maasserver_tag | 64 kB | 65536
piston3_consumer | 2544 kB | 2605056
piston3_nonce | 15 MB | 16146432
piston3_token | 904 kB | 925696
maasserver_domain | 72 kB | 73728
auth_group_permissions | 32 kB | 32768
maasserver_secret | 264 kB | 270336
maasserver_vaultsecret | 24 kB | 24576
maasserver_bootsourceselection | 64 kB | 65536
maasserver_cacheset | 8192 bytes | 8192
maasserver_config | 64 kB | 65536
maasserver_filestorage | 48 kB | 49152
maasserver_bootresourcefile | 128 kB | 131072
maasserver_script | 144 kB | 147456
maasserver_bootsourcecache | 432 kB | 442368
maasserver_eventtype | 88 kB | 90112
maasserver_filesystemgroup | 64 kB | 65536
maasserver_forwarddnsserver | 24 kB | 24576
maasserver_forwarddnsserver_domains | 32 kB | 32768
maasserver_interfacerelationship | 688 kB | 704512
maasserver_keysource | 24 kB | 24576
maasserver_largefile | 96 kB | 98304
maasserver_licensekey | 24 kB | 24576
maasserver_controllerinfo | 112 kB | 114688
maasserver_event | 2984 MB | 3128549376
maasserver_bmcroutablerackcontrollerrelationship | 184 kB | 188416
maasserver_nodeconfig | 200 kB | 204800
maasserver_blockdevice | 3040 kB | 3112960
maasserver_nodedevicevpd | 1648 kB | 1687552
maasserver_nodemetadata | 1824 kB | 1867776
maasserver_nodeuserdata | 2200 kB | 2252800
maasserver_notification | 80 kB | 81920
maasserver_notificationdismissal | 64 kB | 65536
maasserver_numanode | 448 kB | 458752
maasserver_nodedevice | 25 MB | 25911296
maasserver_interface | 5728 kB | 5865472
maasserver_physicalblockdevice | 1384 kB | 1417216
maasserver_numanodehugepages | 88 kB | 90112
maasserver_ownerdata | 32 kB | 32768
maasserver_packagerepository | 64 kB | 65536
maasserver_filesystem | 1264 kB | 1294336
maasserver_partitiontable | 152 kB | 155648
maasserver_podhints | 88 kB | 90112
maasserver_partition | 472 kB | 483328
maasserver_podhints_nodes | 32 kB | 32768
maasserver_podstoragepool | 48 kB | 49152
maasserver_rbaclastsync | 32 kB | 32768
maasserver_rbacsync | 16 kB | 16384
maasserver_rdns | 824 kB | 843776
maasserver_regioncontrollerprocess | 88 kB | 90112
maasserver_regioncontrollerprocessendpoint | 96 kB | 98304
maasserver_regionrackrpcconnection | 112 kB | 114688
maasserver_scriptset | 1264 kB | 1294336
maasserver_vlan | 168 kB | 172032
maasserver_service | 144 kB | 147456
maasserver_space | 48 kB | 49152
maasserver_sshkey | 72 kB | 73728
maasserver_sslkey | 32 kB | 32768
maasserver_node | 1648 kB | 1687552
maasserver_interface_ip_addresses | 2680 kB | 2744320
maasserver_dnsresource_ip_addresses | 336 kB | 344064
maasserver_bmc | 456 kB | 466944
maasserver_subnet | 64 kB | 65536
maasserver_staticroute | 40 kB | 40960
maasserver_iprange | 72 kB | 73728
maasserver_staticipaddress | 2824 kB | 2891776
maasserver_nodegrouptorackcontroller | 16 kB | 16384
maasserver_node_tags | 384 kB | 393216
maasserver_userprofile | 40 kB | 40960
maasserver_dhcpsnippet | 96 kB | 98304
maasserver_versionedtextfile | 664 kB | 679936
maasserver_scriptresult | 1287 MB | 1349427200
maasserver_template | 40 kB | 40960
maasserver_virtualmachine | 128 kB | 131072
maasserver_virtualmachinedisk | 144 kB | 147456
maasserver_virtualmachineinterface | 232 kB | 237568
(105 rows)
Our database has only grown to 15GB over years of use, but I am interested in pruning old material from it. Is there advice available for that? I don’t want to wipe any existing machines.
That database is now 18GB. During our failed upgrade 3.4.4 → 3.5.x I noticed the database shrink to 8GB presumably because images were moved out, so that’s good news for when we figure out how to make that succeed. I still reckon there’s a lot of material in there which could be pruned. Is there support for that? Even some kind of experimental ideas would be helpful to look at, since we can take a backup and restore it if there are any problems after we play with it.
I’d suggest to prune the events table and keep only the latest 20% of the events for each machine. I’ve suggested the query to do it here Comment #5 : Bug #2044895 : Bugs : MAAS .
3.4 and 3.5 have some automatic cleanups at every restart, so orphan ip addresses and dns records should be already pruned there.
Excellent, thank you!
