CIS compliant storage with TPM/LUKS encryption
with curtin preseeds going away what is the way to handle this? I can create CIS compliant storage layout (/boot/efi, /boot and rest in LVM) using maas-cli just fine and it works. However I need to add encryption to the partition where LVM resides and I poked around in maas-cli to find encryption option but can’t find it anywhere. Can it be done by set-storage-layout via custom json somehow? the forum posts on this are outdated and use preseeds while AI goes straight into nothing. Was anyone able to accomplish this? I can share the storage script I’m using if that helps. Thank you in advance!
Hi there, it’s not supported out of the box. Maybe Encrypted filesystem support? can help
