Interface configuration cannot be modified unless the machine is New, Ready, Allocated or Broken.
See https://bugs.launchpad.net/maas-ui/+bug/2032720 .
In general a user should not be able to modify the interfaces of a deployed machine.
Thanks r00ta. How can I make the records on MAAS consistent with the physical changes we made to the deployed machines?
You can enable the HW sync and let MAAS take care of it
It’s an ESXi instance, whose image was made by maas packer. I am considering changing the IP address by altering the MAAS db directly.
