Hello!
Are you guys deploying CentOS 7 with MaaS 2.5?
I have a fully operational MaaS 2.5 environment, where I can deploy Ubuntu 18.04 on both Real and Virtual Machines.
However, I selected CentOS 7 to sync, it is downloaded / synced but, when I try to deploy it, it fails.
I google about it and it looks like that it’s something related with the fact that CentOS 7 comes with its networks closed by default somehow…
Any idea?
Cheers!
BTW, I noticed that CentOS was installed but, it freezes on its first boot, not finishing the MaaS deployment.
I even tried to use the “CentOS Rescue” at its Grub but, it also freezes. No root login anywhere.
tcorej
13 February 2019 21:45
3
I’ve had similar issue and it was because some packages needed for cloud-init oauth were missing. Put this into your preseed file to a late_command section:
10_install_oauth: curtin in-target – yum install -y python-oauthlib python-oauth liboauth
We did have an issue where the oauth package went missing in January, that has been fixed.
@tmartins can you make sure your images are in sync? /var/lib/maas/boot-resources/current/centos/amd64/generic/centos70/daily/root-tgz should have a SHA256SUM of dcbf759f0fae1623c40ebc8dcf1e83a6f83c35eabf0b7cf30932d3db9baaf81d for the latest image.
Yep, that’s the exactly sha256sum that I have! I installed this MaaS few days ago, images sync everyday.
But it still fails.
I’ll try that curtin thing but, I hope that it doesn’t break Ubuntu deployments.
I honestly don’t know which file exactly to add that “in-target” line.
Ok, found the “curtin_userdata_centos” and added the following line at the end of it:
Testing it now!
No, didn’t worked… Do I have to restart services after updating the curtin* files?
I manage to record a video and here is a screenshot in the moment that it fails:
https://imgur.com/a/D5g3Rft
I restored the original curtin_userdata_centos file before.
It’s trying to connect to the yum repos via IPv6! I’m sure that I don’t have IPv6 (no gateway6, no RA, no DHCPv6, just Link-Local “fe80…”).
No idea why CentOS is trying to reach the Internet6 while there is no signal of IPV6 in my lab.
AHA! Some progress!
I changed the MaaS’ PXE Boot network for the CentOS VM, from AutoAssign, to DHCP, then, it worked!
Well, almost…
At least now I can see CentOS login!
But, on MaaS, it shows as “Failed deployment”… Work in this next problem now!
Somehow, after trying and trying… It’s working now!
system
Closed
8 September 2020 19:32
11
