Hey there!
Any reason you guys can think of that MAAS>Take action>Deploy CentOS 7 would produce different results than juju add-machine --base centos@7
The machine fails (30min timeout) if I use Juju, but succeeds normally from the MAAS GUI.
This machine has an XFS partition in addition to the root EXT4, and if I remove that XFS partition it works from both sides…
I get the same issue if I have commissioning OS set to 22.04, so I think somehow Juju is overriding the commissioning OS when it requests the deploy o_O?
Anyone experienced this?
