Can't deploy Ubuntu newer than Bionic if using bond interfaces
Hey MAAStronauts,
A known bug prevents the deployment of Ubuntu versions newer than Bionic when the machine uses a bonded network interface to communicate with the MAAS rack or region controller.
For reference, here’s the bug Bug #2106671 “Deployments using a bonded interface on the “MAAS”...” : Bugs : MAAS . The fix is ongoing and will be available in the next images published in images.maas.io.
Thanks for heads up! Seems like a really breaking change in cloud-init caused that!
A new jammy stable image with the fix is available on images.maas.io.
Also for noble a new stable image is available.
