I had a machine in MAAS which I deployed. After deployment, I manually installed maas-rack-controller and pointed it to the Region Controller, so a new rack appeared.
Then I configured this rack controller as secondary rack controller for a VLAN.
Finally, I tried to delete this new rack controller and came across this error in the CLI:
maas version :2.9.2 Can not find the action to set rack to NULL.
I try to update vlan with cli . like maas admin vlan update 28 0 primary_rack="" maas admin vlan update 28 0 secondary_rack=""
It’s work!!!
If rack is deleted, you can only update it through the database.
