Candid integration to MAAS UI login with ldaps
I am able to integrate candid for MAAS UI login with ldap authentication, will MAAS support ldaps as well which is secure ldap.
Hey @hekarana
Candid supports ldap so as long as you integrated Candid with MAAS I think that should work
Hi @alemar99,
Candid supports ldaps?
Ah sorry I’ve misread. No unfortunately it seems that candid doesn’t support ldaps: Missing LDAPS support · Issue #168 · canonical/candid · GitHub
Thanks for confirming @alemar99
