Can MAAS reflect IP/Network changes on machines which we initially deployed using MAAS
I have deployed a machine using MAAS and the changed the machine’s IP and created a bond manually. But MAAS is still showing me the old IP and NIC details. Is there anyway can MAAS sync with the changes that apply on the machines manually?
You can enable the hardware sync feature https://maas.io/docs/about-deploying-running-machines
