This tutorial provides an in-depth walkthrough of installing, configuring, and preparing MAAS to manage your physical server infrastructure.
Installing MAAS
To install MAAS on your Ubuntu host:
Update your package index and install dependencies:
sudo apt update sudo apt install snapd lxd lxd-client python3-lxc python3-openstackclient
Install the MAAS snap package:
sudo snap install maas --classic
Install the PostgreSQL database:
sudo apt install postgresql postgresql-contrib
Switch to the postgres user and open the PostgreSQL shell:
sudo su - postgres psql
Create a database user for MAAS:
CREATE USER maas WITH PASSWORD 'password';
Create the MAAS database:
CREATE DATABASE maasdb OWNER maas;
Exit PostgreSQL and return to your regular user:
\q exit
Edit
/etc/postgresql/12/main/pg_hba.conf
, adding a line like the one below, to allow the MAAS user to connect:sudo vi /etc/postgresql/12/main/pg_hba.conf host $MAAS_DBNAME $MAAS_DBUSER 0/0 md5
Initialize MAAS, specifying the PostgreSQL URL:
sudo maas init region+rack --database-uri postgres://maas:password@localhost/maasdb
Visit the web UI and create your admin account.
MAAS is now installed!
Configuring MAAS
After installing, complete further configuration:
Access MAAS at this address, where
$API_HOST
is the MAAS URL which was generated earlier:http://${API_HOST}:5240/MAAS
Log in using the login information you created when initializing MAAS.
In the web UI, go to Settings > General and set a forward DNS server, such as “8.8.8.8”.
Under Images, select the Ubuntu release to sync; you can usually accept the default.
Under Accounts, import your SSH public key from Launchpad or GitHub, or upload your existing public key. Follow the on-screen instructions.
Review remaining config options like proxy usage, NTP, etc.
MAAS can now manage and provision nodes.
Setting up LXD
To manage LXD containers alongside physical servers:
Install the LXD snap:
sudo snap install lxd
Initialize the LXD configuration:
sudo lxd init
Choose appropriate options for networking, storage pools, etc.
Disable LXD’s built-in DHCP server:
Configuring Networking and DHCP
Finally, configure networking and DHCP:
Identify the LXD bridge IP address:
ip addr show lxdbr0
In MAAS, go to Subnets and identify the VLAN for that subnet.
Select the VLAN and configure DHCP with the bridge IP as the gateway.
MAAS now provides networking and DHCP for provisioning.
