Is this what you are looking for?
"default_macvlan_mode": null,
"type": "lxd",
"cpu_over_commit_ratio": 1.0,
"tags": [
"pod-console-logging"
"id": 93,
"total": {
"cores": 24,
"memory": 131072,
"local_storage": 491097079808
"storage_pools": [
"id": "default",
"name": "default",
"type": "dir",
"path": "Unknown",
"total": 491097079808,
"used": 0,
"available": 491097079808,
"default": true
"name": "honest-swift",
"host": {
"system_id": "4waapd",
"__incomplete__": true
"pool": {
"name": "default",
"id": 0,
"available": {
"cores": 24,
"memory": 131072,
"version": "5.21.2",
"architectures": [
"amd64/generic"
"capabilities": [
"composable",
"dynamic_local_storage",
"over_commit",
"storage_pools"
"used": {
"cores": 0,
"memory": 0,
"local_storage": 0
"zone": {
"name": "default",
"description": "",
"id": 1,
"resource_uri": "/MAAS/api/2.0/vm-hosts/93/"
Here is machine info.
"last_sync": null,
"default_gateways": {
"ipv4": {
"gateway_ip": "10.1.30.1",
"link_id": null
"ipv6": {
"gateway_ip": null,
"link_id": null
"testing_status": 2,
"tag_names": [],
"current_testing_result_id": 241,
"power_type": "ipmi",
"swap_size": null,
"virtualblockdevice_set": [
"storage_pool": null,
"available_size": 0,
"type": "virtual",
"partition_table_type": null,
"id_path": null,
"numa_node": null,
"partitions": [],
"size": 500095254528,
"name": "vgroot-lvroot",
"id": 171,
"block_size": 4096,
"uuid": "dd363575-db64-4d3c-948c-6e854d967d17",
"filesystem": {
"fstype": "ext4",
"label": "root",
"uuid": "e315d30c-1021-446a-8560-a9915d1104ee",
"mount_point": "/",
"mount_options": null
"model": null,
"tags": [],
"serial": null,
"used_size": 500095254528,
"resource_uri": "/MAAS/api/2.0/nodes/4waapd/blockdevices/171/"
"network_test_status": -1,
"pod": null,
"node_type_name": "Machine",
"ip_addresses": [
"10.1.30.235",
"10.1.40.72",
"10.195.49.1",
"fd42:6f86:98e4:a1ce::1"
"storage_test_status": 2,
"osystem": "ubuntu",
"other_test_status": -1,
"cpu_test_status": -1,
"enable_hw_sync": false,
"power_state": "on",
"status_action": "",
"locked": false,
"volume_groups": [
"id": 111,
"hardware_uuid": "00000000-0000-0000-0000-0cc47a6b1bea",
"memory": 131072,
"workload_annotations": {},
"physicalblockdevice_set": [
"firmware_version": "3B6Q",
"type": "physical",
"partition_table_type": "GPT",
"id_path": "/dev/disk/by-id/wwn-0x5002538d4228716d",
"numa_node": 0,
"partitions": [
"uuid": "96d0d99f-c71a-4ab4-ba52-a4c518a3ca2c",
"size": 500099448832,
"bootable": false,
"tags": [],
"filesystem": {
"fstype": "lvm-pv",
"label": null,
"uuid": "286efe37-22b5-491d-b6e5-d15350caef50",
"mount_point": null,
"id": 113,
"type": "partition",
"path": "/dev/disk/by-dname/sda-part2",
"device_id": 166,
"resource_uri": "/MAAS/api/2.0/nodes/4waapd/blockdevices/166/partition/113"
"used_for": "GPT partitioned with 1 partition",
"size": 500107862016,
"name": "sda",
"id": 166,
"block_size": 512,
"uuid": null,
"filesystem": null,
"model": "Samsung SSD 850",
"tags": [
"ssd"
"serial": "S3PTNB0J801776B",
"used_size": 500105740288,
"resource_uri": "/MAAS/api/2.0/nodes/4waapd/blockdevices/166/"
"zone": {
"name": "default",
"description": "",
"id": 1,
"storage": 500107.86201599997,
"status_name": "Deployed",
"hostname": "honest-swift",
"fqdn": "honest-swift.insecure-it.local",
"status_message": "Rebooting",
"parent": null,
"blockdevice_set": [
"type": "physical",
"numa_node": 0,
"partitions": [
"bootable": false,
"tags": [],
"filesystem": {
"fstype": "lvm-pv",
"label": null,
"id": 113,
"device_id": 166,
"name": "sda",
"id": 166,
"block_size": 512,
"uuid": null,
"filesystem": null,
"tags": [
"ssd"
"type": "virtual",
"id_path": null,
"numa_node": null,
"partitions": [],
"id": 171,
"block_size": 4096,
"filesystem": {
"fstype": "ext4",
"label": "root",
"mount_point": "/",
"model": null,
"tags": [],
"serial": null,
"domain": {
"authoritative": true,
"ttl": null,
"is_default": true,
"name": "insecure-it.local",
"id": 0,
"resource_record_count": 0,
"status": 6,
"current_installation_result_id": 246,
"interface_set": [
"mac_address": "0c:c4:7a:6b:1b:ea",
"type": "physical",
"link_connected": true,
"enabled": true,
"product": "I350 Gigabit Network Connection",
"effective_mtu": 1500,
"numa_node": 0,
"children": [
"br-eno1"
"discovered": null,
"sriov_max_vf": 7,
"links": [],
"interface_speed": 1000,
"name": "eno1",
"id": 419,
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": true,
"external_dhcp": null,
"relay_vlan": null,
"secondary_rack": null,
"fabric_id": 0,
"name": "untagged",
"id": 1,
"primary_rack": "p67brc",
"space": "undefined",
"fabric": "pxe-fabric",
"resource_uri": "/MAAS/api/2.0/vlans/1/"
"parents": [],
"firmware_version": "1.52.0",
"params": {},
"vendor": "Intel Corporation",
"tags": [
"sriov"
"link_speed": 1000,
"resource_uri": "/MAAS/api/2.0/nodes/4waapd/interfaces/419/"
"mac_address": "0c:c4:7a:6b:1b:eb",
"type": "physical",
"enabled": true,
"numa_node": 0,
"children": [
"br-eno2"
"discovered": null,
"sriov_max_vf": 7,
"links": [],
"name": "eno2",
"id": 422,
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"fabric_id": 45,
"name": "untagged",
"id": 54,
"primary_rack": null,
"fabric": "iscsi-fabric",
"resource_uri": "/MAAS/api/2.0/vlans/54/"
"parents": [],
"params": {},
"tags": [
"sriov"
"link_speed": 1000,
"resource_uri": "/MAAS/api/2.0/nodes/4waapd/interfaces/422/"
"mac_address": "00:15:17:7d:b7:90",
"type": "physical",
"enabled": true,
"product": "82571EB/82571GB Gigabit Ethernet Controller D0/D1 (copper applications)",
"numa_node": 1,
"children": [
"vlan"
"discovered": null,
"sriov_max_vf": 0,
"links": [],
"name": "enp133s0f0",
"id": 424,
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"fabric_id": 5,
"name": "untagged",
"id": 10,
"fabric": "vlan-trunk-fabric",
"resource_uri": "/MAAS/api/2.0/vlans/10/"
"parents": [],
"firmware_version": "5.6-2",
"params": {},
"tags": [],
"link_speed": 1000,
"resource_uri": "/MAAS/api/2.0/nodes/4waapd/interfaces/424/"
"mac_address": "00:15:17:7d:b7:91",
"type": "physical",
"enabled": true,
"numa_node": 1,
"children": [
"vlan"
"discovered": null,
"sriov_max_vf": 0,
"links": [],
"name": "enp133s0f1",
"id": 426,
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"fabric_id": 5,
"name": "untagged",
"id": 10,
"parents": [],
"params": {},
"tags": [],
"link_speed": 1000,
"resource_uri": "/MAAS/api/2.0/nodes/4waapd/interfaces/426/"
"type": "bond",
"link_connected": false,
"enabled": true,
"product": null,
"numa_node": null,
"children": [
"vlan.10",
"vlan.20"
"discovered": null,
"sriov_max_vf": 0,
"links": [
"id": 1593,
"mode": "link_up"
"interface_speed": 0,
"name": "vlan",
"id": 431,
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"fabric_id": 5,
"name": "untagged",
"id": 10,
"parents": [
"enp133s0f0",
"enp133s0f1"
"firmware_version": null,
"params": {
"bond_mode": "802.3ad",
"bond_miimon": 1,
"bond_updelay": 0,
"bond_downdelay": 0,
"bond_lacp_rate": "fast",
"bond_num_grat_arp": 1,
"bond_xmit_hash_policy": "layer2"
"vendor": null,
"tags": [],
"link_speed": 0,
"resource_uri": "/MAAS/api/2.0/nodes/4waapd/interfaces/431/"
"type": "vlan",
"enabled": true,
"product": null,
"numa_node": null,
"children": [],
"discovered": null,
"sriov_max_vf": 0,
"links": [
"id": 1594,
"mode": "link_up"
"name": "vlan.10",
"id": 432,
"vlan": {
"vid": 10,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"fabric_id": 5,
"name": "inet-vlan",
"id": 12,
"resource_uri": "/MAAS/api/2.0/vlans/12/"
"parents": [
"vlan"
"params": {},
"vendor": null,
"tags": [],
"link_speed": 0,
"resource_uri": "/MAAS/api/2.0/nodes/4waapd/interfaces/432/"
"type": "vlan",
"enabled": true,
"product": null,
"numa_node": null,
"children": [],
"discovered": null,
"sriov_max_vf": 0,
"links": [
"id": 1595,
"mode": "link_up"
"name": "vlan.20",
"id": 433,
"vlan": {
"vid": 20,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": true,
"relay_vlan": null,
"fabric_id": 0,
"name": "untagged",
"id": 1,
"fabric_id": 5,
"name": "server-vlan",
"id": 11,
"resource_uri": "/MAAS/api/2.0/vlans/11/"
"parents": [
"vlan"
"params": {},
"vendor": null,
"tags": [],
"link_speed": 0,
"resource_uri": "/MAAS/api/2.0/nodes/4waapd/interfaces/433/"
"type": "bridge",
"enabled": true,
"product": null,
"numa_node": null,
"children": [],
"discovered": null,
"sriov_max_vf": 0,
"links": [
"id": 1562,
"mode": "static",
"ip_address": "10.1.30.235",
"subnet": {
"name": "default-pxe-subnet",
"description": "",
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": true,
"relay_vlan": null,
"fabric_id": 0,
"name": "untagged",
"id": 1,
"cidr": "10.1.30.0/24",
"rdns_mode": 2,
"dns_servers": [
"10.1.30.10"
"allow_dns": true,
"allow_proxy": true,
"active_discovery": true,
"managed": true,
"disabled_boot_architectures": [],
"id": 1,
"resource_uri": "/MAAS/api/2.0/subnets/1/"
"name": "br-eno1",
"id": 440,
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": true,
"relay_vlan": null,
"fabric_id": 0,
"name": "untagged",
"id": 1,
"parents": [
"eno1"
"params": {
"bridge_fd": 15,
"bridge_stp": false,
"bridge_type": "standard"
"vendor": null,
"tags": [],
"link_speed": 0,
"resource_uri": "/MAAS/api/2.0/nodes/4waapd/interfaces/440/"
"type": "bridge",
"enabled": true,
"product": null,
"numa_node": null,
"children": [],
"discovered": null,
"sriov_max_vf": 0,
"links": [
"id": 1592,
"mode": "static",
"ip_address": "10.1.40.72",
"subnet": {
"name": "icsi-subnet",
"description": "",
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"fabric_id": 45,
"name": "untagged",
"id": 54,
"cidr": "10.1.40.0/24",
"rdns_mode": 2,
"gateway_ip": null,
"dns_servers": [],
"allow_dns": true,
"active_discovery": false,
"managed": true,
"id": 23,
"resource_uri": "/MAAS/api/2.0/subnets/23/"
"name": "br-eno2",
"id": 441,
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"fabric_id": 45,
"name": "untagged",
"id": 54,
"parents": [
"eno2"
"params": {
"bridge_fd": 15,
"vendor": null,
"tags": [],
"link_speed": 0,
"resource_uri": "/MAAS/api/2.0/nodes/4waapd/interfaces/441/"
"mac_address": "00:16:3e:6e:1d:66",
"type": "bridge",
"enabled": true,
"product": null,
"numa_node": null,
"children": [],
"discovered": null,
"sriov_max_vf": 0,
"links": [
"id": 1590,
"mode": "static",
"ip_address": "10.195.49.1",
"subnet": {
"name": "10.195.49.0/24",
"description": "",
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"fabric_id": 123,
"name": "untagged",
"id": 132,
"fabric": "fabric-123",
"resource_uri": "/MAAS/api/2.0/vlans/132/"
"cidr": "10.195.49.0/24",
"rdns_mode": 2,
"gateway_ip": null,
"dns_servers": [],
"allow_dns": true,
"managed": true,
"id": 56,
"resource_uri": "/MAAS/api/2.0/subnets/56/"
"id": 1591,
"mode": "static",
"ip_address": "fd42:6f86:98e4:a1ce::1",
"subnet": {
"name": "fd42:6f86:98e4:a1ce::/64",
"description": "",
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"fabric_id": 123,
"name": "untagged",
"id": 132,
"cidr": "fd42:6f86:98e4:a1ce::/64",
"rdns_mode": 2,
"gateway_ip": null,
"dns_servers": [],
"allow_dns": true,
"managed": true,
"id": 57,
"resource_uri": "/MAAS/api/2.0/subnets/57/"
"name": "lxdbr0",
"id": 446,
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"relay_vlan": null,
"fabric_id": 123,
"name": "untagged",
"id": 132,
"parents": [],
"params": {},
"vendor": null,
"tags": [],
"link_speed": 0,
"resource_uri": "/MAAS/api/2.0/nodes/4waapd/interfaces/446/"
"current_commissioning_result_id": 240,
"node_type": 0,
"virtualmachine_id": null,
"disable_ipv4": false,
"interface_test_status": -1,
"bios_boot_method": "pxe",
"address_ttl": null,
"next_sync": null,
"owner_data": {},
"min_hwe_kernel": "",
"error_description": "",
"sync_interval": null,
"distro_series": "jammy",
"pool": {
"name": "default",
"id": 0,
"cpu_count": 24,
"netboot": false,
"owner": "arozar",
"raids": [],
"boot_interface": {
"type": "physical",
"enabled": true,
"numa_node": 0,
"children": [
"br-eno1"
"discovered": null,
"sriov_max_vf": 7,
"links": [],
"name": "eno1",
"id": 419,
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": true,
"relay_vlan": null,
"fabric_id": 0,
"name": "untagged",
"id": 1,
"parents": [],
"params": {},
"tags": [
"sriov"
"link_speed": 1000,
"commissioning_status": 2,
"boot_disk": {
"type": "physical",
"numa_node": 0,
"partitions": [
"bootable": false,
"tags": [],
"filesystem": {
"fstype": "lvm-pv",
"label": null,
"id": 113,
"device_id": 166,
"name": "sda",
"id": 166,
"block_size": 512,
"uuid": null,
"filesystem": null,
"tags": [
"ssd"
"memory_test_status": -1,
"bcaches": [],
"ephemeral_deploy": false,
"special_filesystems": [],
"description": "",
"cpu_speed": 2600,
"cache_sets": [],
"numanode_set": [
"index": 0,
"memory": 65536,
"cores": [
0,
12,
1,
13,
14,
2,
15,
3,
16,
4,
17,
5
"hugepages_set": [
"page_size": 2097152,
"total": 0
"index": 1,
"memory": 65536,
"cores": [
18,
6,
19,
7,
20,
8,
21,
9,
10,
22,
11,
23
"hugepages_set": [
"total": 0
"hardware_info": {
"system_vendor": "Supermicro",
"system_product": "SYS-6017R-TDLR-BK0-LC019",
"system_family": "To be filled by O.E.M.",
"system_version": "Unknown",
"system_sku": "To be filled by O.E.M.",
"system_serial": "S15792125801102",
"cpu_model": "Intel(R) Xeon(R) CPU E5-2630 v2",
"mainboard_vendor": "Supermicro",
"mainboard_product": "X9DRD-iF",
"mainboard_serial": "NM157S001871",
"mainboard_version": "REV:1.10",
"mainboard_firmware_vendor": "American Megatrends Inc.",
"mainboard_firmware_date": "09/10/2018",
"mainboard_firmware_version": "3.3",
"chassis_vendor": "Supermicro",
"chassis_type": "Other",
"chassis_serial": "C8130LE04N90406",
"chassis_version": "Unknown"
"hwe_kernel": "ga-22.04",
"resource_uri": "/MAAS/api/2.0/machines/4waapd/"
