bind9 not enabled on rack controller
Could anybody offer some pointers as to why bind9 is not enabled on my second rack controller in MaaS 3.7.1?
$ sudo /snap/bin/maas status
Service Startup Current Since
agent disabled active today at 14:38 UTC
bind9 disabled inactive -
dhcpd disabled active today at 19:00 UTC
dhcpd6 disabled inactive -
http disabled active today at 14:37 UTC
ntp disabled active today at 14:38 UTC
proxy disabled inactive -
rackd enabled active today at 14:37 UTC
syslog disabled active today at 14:38 UTC
It’s not showing up in the GUI as enabled either. I don’t see anywhere in the GUI to enable DNS on a rack server. The subnet exists as a secondary for DHCP and DHCP is working properly on the rack controller. MaaS is also advertising the primary and secondary rack controller via DHCP as DNS servers. Which is failing as DNS is not running on it.
Any ideas?
Hi @ry4nm1
What is the current configuration of the subnet?
Could you provide me with the output of maas $PROFILE subnet read <subnet_id> or alternatively look for the subnet in the networks page of the UI?
You should see an “allow_dns” option or “Allow DNS Resolution” checkbox respectively.
Hi @ry4nm1
That might be a valid bug. We moved to the custom implementation of the DNS resolver (provided by the agent service) so we no longer depend on bind9 when you install MAAS in a rack only mode. DNS should work, but I agree, seeing bind9 being disabled is very misleading.
Can you please confirm if you have your second rack controller installed as maas init rack and that this issue does happen only in this case?
“name”: “192.168.0.0/22”,
“description”: “”,
“vlan”: {
“vid”: 0,
“mtu”: 1500,
“dhcp_on”: true,
“external_dhcp”: null,
“relay_vlan”: null,
“id”: 5002,
“name”: “untagged”,
“space”: “NAT-Space”,
“fabric_id”: 1,
“primary_rack”: “7gr7rw”,
“fabric”: “1G-maas-fabric”,
“secondary_rack”: “emsfad”,
“resource_uri”: “/MAAS/api/2.0/vlans/5002/”
“cidr”: “192.168.0.0/22”,
“rdns_mode”: 2,
“gateway_ip”: “192.168.0.1”,
“dns_servers”: [
“192.168.0.53”,
“192.168.0.5”
“allow_dns”: true,
“allow_proxy”: true,
“active_discovery”: true,
“managed”: true,
“disabled_boot_architectures”: ,
“id”: 2,
“resource_uri”: “/MAAS/api/2.0/subnets/2/”
It’s interesting that the dns_servers here are .5 and .53. .4 is the region/rack controller, .5 is my secondary rack controller, and .53 is an external DNS server. I wonder why .4 is not in the list…
The DHCP server is handing out:
DNS Servers . . . . . . . . . . . :
192.168.0.5
192.168.0.4
192.168.0.53
192.168.0.5
Which is also weird that it’s providing .5 twice.
Yes, the second rack controller was installed with:
maas init rack –maas-url –secret XXXXX
OK, maas-agent is actually listening on udp/tcp 53. I wasn’t looking for another process on 53, just looking for bind9 before…
$sudo ss -alpn | grep 53
u_str LISTEN 0 4096 /run/lvm/lvmpolld.socket 5365 * 0 users:((“systemd”,pid=1,fd=111))
u_str LISTEN 0 4096 /run/systemd/fsck.progress 5368 * 0 users:((“systemd”,pid=1,fd=117))
u_str LISTEN 0 4096 @/org/kernel/linux/storage/multipathd 5367 * 0 users:((“multipathd”,pid=528230,fd=3),(“systemd”,pid=1,fd=126))
udp UNCONN 0 0 192.168.0.5:53 0.0.0.0:* users:((“maas-agent”,pid=1142,fd=30))
udp UNCONN 0 0 192.168.240.5:53 0.0.0.0:* users:((“maas-agent”,pid=1142,fd=28))
udp UNCONN 0 0 127.0.0.54:53 0.0.0.0:* users:((“systemd-resolve”,pid=635,fd=16))
udp UNCONN 0 0 127.0.0.53%lo:53 0.0.0.0:* users:((“systemd-resolve”,pid=635,fd=14))
tcp LISTEN 0 4096 192.168.240.5:53 0.0.0.0:* users:((“maas-agent”,pid=1142,fd=29))
tcp LISTEN 0 4096 192.168.0.5:53 0.0.0.0:* users:((“maas-agent”,pid=1142,fd=31))
tcp LISTEN 0 4096 127.0.0.54:53 0.0.0.0:* users:((“systemd-resolve”,pid=635,fd=17))
tcp LISTEN 0 4096 0.0.0.0:22 0.0.0.0:* users:((“sshd”,pid=11136,fd=3),(“systemd”,pid=1,fd=153))
tcp LISTEN 0 4096 127.0.0.53%lo:53 0.0.0.0:* users:((“systemd-resolve”,pid=635,fd=15))
But it’s not responding to anything on the interface IP:
$ dig -t A www.google.c @192.168.0.5
;; communications error to 192.168.0.5#53: timed out
; <<>> DiG 9.18.39-0ubuntu0.24.04.2-Ubuntu <<>> -t A www.google.c @192.168.0.5
;; global options: +cmd
;; no servers could be reached
But it is responding on the .54 loopback:
dig -t A www.google.c @127.0.54
; <<>> DiG 9.18.39-0ubuntu0.24.04.2-Ubuntu <<>> -t A www.google.c @127.0.54
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 19561
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 65494
; COOKIE: b7227167f0987ab00100000069a5813e4bddf982b249939c (good)
;; QUESTION SECTION:
;www.google.c. IN A
;; ANSWER SECTION:
www.google.c. 296 IN A 142.251.40.228
;; Query time: 2 msec
;; SERVER: 127.0.0.54#53(127.0.54) (UDP)
;; WHEN: Mon Mar 02 12:23:26 UTC 2026
;; MSG SIZE rcvd: 87
So, this looks like a filtering issue. iptables/nftables are not deployed. Any ideas?
MAAS doesn’t modify iptables/nftables during installation
It looks like the DNS agent on the rack controller is not respecting the “forwarder” option in the maas configuration and trying to query public DNS servers directly. In my case, this is running in an environment where the IT firewalls block all DNS except to their DNS servers which I need to use as a forwarding.
Do you see this in a region+rack controller or in a rack-only controller?
