Tailing /var/snap/maas/common/log/named.log
, I always see this:
26-Oct-2021 11:16:25.085 rejected command channel message from 192.168.1.25#37765
Then it looks like it restarts bind and the same thing repeats again. But before the line above shows, bind actually works because I can run queries against it and it resolves fine.
My upstream DNS on MAAS UI is set to 8.8.8.8 8.8.4.4
and DNSSEC is disabled.
/var/snap/maas/common/log/maas.log
shows this:
021-10-26T11:18:26.018082+00:00 localhost maas.service_monitor: [info] Service 'bind9' is not on, it will be started.
2021-10-26T11:18:27.481623+00:00 localhost maas.service_monitor: [error] Service 'bind9' failed to start. Its current state is 'dead' and 'Result: exit-code'.
2021-10-26T11:18:28.112307+00:00 localhost maas.dns: [error] Reloading BIND failed (is it running?): Command `rndc -c /var/snap/maas/15003/bind/rndc.conf.maas reload` returned non-zero exit status 1:#012rndc: connect failed: 127.0.0.1#954: connection refused
2021-10-26T11:18:29.652062+00:00 localhost maas.service_monitor: [info] Service 'bind9' is not on, it will be started
/var/snap/maas/current/bind/named.conf.rndc.maas
which is included in named.conf
have this:
key "rndc-maas-key" {
algorithm hmac-sha256;
secret "xqeVeDCFgI12qv+fEzuxYl5xZH8M+5DQzV+sWWEEAOA=";
controls {
inet 127.0.0.1 port 954
allow { 127.0.0.1; } keys { "rndc-maas-key"; };
And I can see that it only allows 127.0.0.1
that’s why I think requests from 192.168.1.25
are blocked.
But /var/snap/maas/current/bind/rndc.conf.maas
have this:
options {
default-key "rndc-maas-key";
default-server 127.0.0.1;
default-port 954;
# End of rndc.conf
So I don’t know why it’s sending/getting requests from 192.168.1.25
which is btw one of the interfaces on the MAAS instance.
I was originally running 2.9
when the issue occurred and thought of upgrading to 3.0
by running sudo snap refresh --channel=3.0/stable maas
but it’s still the same.
I’ve been on this for quite a while now so I would really appreciate if there’s someone who can help.
