I noticed the same behaviour on my region server
- Ubuntu 18.04 (VM)
- MaaS 2.7.0 (snap install)
This is an extract from my /var/snap/maas/common/log/supervisor-run.log
2020-05-05 15:15:15,352 INFO spawned: 'bind9' with pid 8827
2020-05-05 15:15:17,253 INFO success: bind9 entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2020-05-05 15:15:18,616 INFO exited: bind9 (terminated by SIGKILL; not expected)
2020-05-05 15:15:18,633 INFO spawned: 'bind9' with pid 8848
2020-05-05 15:15:19,996 INFO success: bind9 entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2020-05-05 15:15:22,072 INFO exited: bind9 (terminated by SIGKILL; not expected)
2020-05-05 15:15:22,110 INFO spawned: 'bind9' with pid 8877
2020-05-05 15:15:23,116 INFO success: bind9 entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2020-05-05 15:15:26,691 INFO exited: bind9 (terminated by SIGKILL; not expected)
This is an extract from /var/snap/maas/common/log/regiond.log
2020-05-05 13:27:06 maasserver.region_controller: [critical] Failed configuring DNS; killing and restarting
File "/snap/maas/5229/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 459, in callback
self._startRunCallbacks(result)
File "/snap/maas/5229/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 567, in _startRunCallbacks
self._runCallbacks()
File "/snap/maas/5229/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 653, in _runCallbacks
File "/snap/maas/5229/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 1532, in unwindGenerator
return _inlineCallbacks(None, gen, Deferred())
File "/snap/maas/5229/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 1386, in _inlineCallbacks
result = g.send(result)
File "/snap/maas/5229/lib/python3.6/site-packages/maasserver/region_controller.py", line 224, in _checkSerial
"Failed to reload DNS; timeout or rdnc command failed."
maasserver.region_controller.DNSReloadError: Failed to reload DNS; timeout or rdnc command failed.
This is an extract from /var/snap/maas/common/log/named.log
05-May-2020 14:59:32.724 starting BIND 9.11.3-1ubuntu1.11-Ubuntu (Extended Support Version) <id:a375815>
05-May-2020 14:59:32.724 running on Linux x86_64 4.15.0-99-generic #100-Ubuntu SMP Wed Apr 22 20:32:56 UTC 2020
05-May-2020 14:59:32.724 built with '--build=x86_64-linux-gnu' '--prefix=/usr' '--includedir=/usr/include' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--sysconfdir=/etc' '--localstatedir=/var' '--disable-silent-rules' '--libdir=/usr/lib/x86_64-linux-gnu' '--libexecdir=/usr/lib/x86_64-linux-gnu' '--disable-maintainer-mode' '--disable-dependency-tracking' '--libdir=/usr/lib/x86_64-linux-gnu' '--sysconfdir=/etc/bind' '--with-python=python3' '--localstatedir=/' '--enable-threads' '--enable-largefile' '--with-libtool' '--enable-shared' '--enable-static' '--with-gost=no' '--with-openssl=/usr' '--with-gssapi=/usr' '--with-libjson=/usr' '--without-lmdb' '--with-gnu-ld' '--with-geoip=/usr' '--with-atf=no' '--enable-ipv6' '--enable-rrl' '--enable-filter-aaaa' '--enable-native-pkcs11' '--with-pkcs11=/usr/lib/softhsm/libsofthsm2.so' '--with-randomdev=/dev/urandom' '--with-eddsa=no' 'build_alias=x86_64-linux-gnu' 'CFLAGS=-g -O2 -fdebug-prefix-map=/build/bind9-uW3Pyl/bind9-9.11.3+dfsg=. -fstack-protector-strong -Wformat -Werror=format-security -fno-strict-aliasing -fno-delete-null-pointer-checks -DNO_VERSION_DATE -DDIG_SIGCHASE' 'LDFLAGS=-Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-z,now' 'CPPFLAGS=-Wdate-time -D_FORTIFY_SOURCE=2'
05-May-2020 14:59:32.724 running as: named -c /var/snap/maas/5229/bind/named.conf -g
05-May-2020 14:59:32.724 ----------------------------------------------------
05-May-2020 14:59:32.724 BIND 9 is maintained by Internet Systems Consortium,
05-May-2020 14:59:32.724 Inc. (ISC), a non-profit 501(c)(3) public-benefit
05-May-2020 14:59:32.724 corporation. Support and training for BIND 9 are
05-May-2020 14:59:32.724 available at https://www.isc.org/support
05-May-2020 14:59:32.724 found 4 CPUs, using 4 worker threads
05-May-2020 14:59:32.724 using 3 UDP listeners per interface
05-May-2020 14:59:32.769 using up to 4096 sockets
05-May-2020 14:59:32.818 loading configuration from '/var/snap/maas/5229/bind/named.conf'
05-May-2020 14:59:32.819 reading built-in trust anchors from file '/snap/maas/current/etc/bind/bind.keys'
05-May-2020 14:59:32.820 GeoIP Country (IPv4) (type 1) DB not available
05-May-2020 14:59:32.820 GeoIP Country (IPv6) (type 12) DB not available
05-May-2020 14:59:32.820 GeoIP City (IPv4) (type 2) DB not available
05-May-2020 14:59:32.820 GeoIP City (IPv4) (type 6) DB not available
05-May-2020 14:59:32.820 GeoIP City (IPv6) (type 30) DB not available
05-May-2020 14:59:32.820 GeoIP City (IPv6) (type 31) DB not available
05-May-2020 14:59:32.820 GeoIP Region (type 3) DB not available
05-May-2020 14:59:32.820 GeoIP Region (type 7) DB not available
05-May-2020 14:59:32.820 GeoIP ISP (type 4) DB not available
05-May-2020 14:59:32.820 GeoIP Org (type 5) DB not available
05-May-2020 14:59:32.820 GeoIP AS (type 9) DB not available
05-May-2020 14:59:32.820 GeoIP Domain (type 11) DB not available
05-May-2020 14:59:32.820 GeoIP NetSpeed (type 10) DB not available
05-May-2020 14:59:32.820 using default UDP/IPv4 port range: [32768, 60999]
05-May-2020 14:59:32.820 using default UDP/IPv6 port range: [32768, 60999]
05-May-2020 14:59:32.822 listening on IPv6 interfaces, port 53
05-May-2020 14:59:32.848 binding TCP socket: address in use
05-May-2020 14:59:32.848 listening on IPv4 interface lo, 127.0.0.1#53
05-May-2020 14:59:32.851 binding TCP socket: address in use
05-May-2020 14:59:32.851 listening on IPv4 interface ens160, 192.168.92.14#53
05-May-2020 14:59:32.866 binding TCP socket: address in use
05-May-2020 14:59:32.867 listening on IPv4 interface virbr0, 192.168.122.1#53
05-May-2020 14:59:32.873 binding TCP socket: address in use
05-May-2020 14:59:32.877 unable to listen on any configured interfaces
05-May-2020 14:59:32.878 loading configuration: failure
05-May-2020 14:59:32.878 exiting (due to fatal error)
These messages are printed continuosly, every time named is restarted. Cannot tell what’s happening. Apparently they first appeared yesterday. I’m still investigating.
Regards,
)+(auloop
