MAAS uses standard command-line utilities to keep backups simple and familiar.
Clean reset backup
This procedure does a clean reset backup using pg_dumpall
. MAAS and PostgreSQL are fully overwritten on restore. You can also do a limited back and restore if other services are sharing your PostgreSQL database.
Generally, using pg_dumpall
for a database dump doesn’t require stopping PostgreSQL. It works with live databases, ensuring consistent backups and minimal service disruption. The PostgreSQL transactional model guarantees dump accuracy. You should be able to keep PostgreSQL running – skipping the optional steps below – but you should stop MAAS first to avoid conflicts during the dump. If you’re concerned at all, just use the optional steps to stop and restart PostgreSQL.
Please note that the order of steps is important.
Clean Snap backup
Use this command, if needed, to confirm the local PostgreSQL service name:
sudo systemctl list-units --type=service | grep postgres
Create an epoch-stamped directory on your external media to store the backup:
cd <external-backup-media>/maas-backups/ mkdir $(date +%s)
Backup the database to your external backup media:
sudo -u postgres pg_dumpall -c > "<external-backup-media>/maas-backups/<backup-timestamp>/$(date +%s)_dump.sql"
Stop MAAS:
sudo snap stop maas
(Optional) Confirm that no other PostgreSQL sessions are active:
sudo -u postgres psql -c "SELECT * FROM pg_stat_activity"
(Optional) Stop PostgreSQL:
sudo systemctl stop postgresql.service
Take a snapshot of MAAS and note the snapshot ID:
sudo snap save maas
Verify the snapshot:
sudo snap check-snapshot <snapshot-id>
Export the snapshot to your external backup media:
sudo snap export-snapshot <snapshot-id> <external-backup-media>/maas-backups/<backup-timestamp>/$(date +%s)_maas_snapshot_<snapshot-id>
(Optional) Restart PostgreSQL:
sudo systemctl start postgresql.service
- (Optional) Verify that PostgreSQL is running:
sudo systemctl status postgresql
- Restart MAAS:
sudo snap restart maas
Clean Snap restore
Stop MAAS to clear any cache:
sudo snap stop maas
Remove the current MAAS instance:
sudo snap remove maas
Do a clean restore of the database:
sudo -u postgres psql -f <external-backup-media>/maas-backups/<backup-timestamp>/<dump_epoch>_dump.sql postgres
Import the MAAS snapshot from external media:
sudo snap import-snapshot <external-backup-media>/maas-backups/<backup-timestamp>/<snapshot-epoch>_maas_snapshot_<snapshot-id>
Restore the MAAS snapshot:
sudo snap restore <snapshot-id>
Restart MAAS:
Clean package backup
Stop MAAS services:
sudo systemctl stop maas-dhcpd.service sudo systemctl stop maas-rackd.service sudo systemctl stop maas-regiond.service
Write a verified archive of the key MAAS files to your external backup:
sudo tar cvpzWf <external-backup-media>/maas-backups/<backup-timestamp>/$(date +%s)_maas_backup.tgz --exclude=/var/lib/maas/boot-resources /etc/maas /var/lib/maas
Restart MAAS:
Clean package restore
(Optional, but recommended if possible) Begin with a fresh Ubuntu install.
Make sure the required PostgreSQL version is installed.
Install MAAS from packages.
Once fully operational, stop these MAAS services:
Untar the backup to a temporary directory:
mkdir /tmp/maas_backup sudo tar xvzpf <external-backup-media>/maas-backups/<backup-timestamp>/$(date +%s)_maas_backup.tgz -C /tmp/maas_backup
Create epoch-stamped backup directories:
backup_dir="/var/backups/maas_backup/$(date +%s)"
sudo mkdir -p "$backup_dir"
- Move current MAAS directories to backup:
sudo mv /etc/maas "$backup_dir/etc_maas"
sudo mv /var/lib/maas "$backup_dir/var_lib_maas"
- Restore MAAS configuration from backup:
sudo cp -prf /tmp/maas_backup/etc/maas /etc/
sudo cp -prf /tmp/maas_backup/var/lib/maas /var/lib/
- Do a clean restore of the database:
- (Optional) Restart PostgreSQL:
- Restart MAAS services:
Limited backup
For MAAS and PostgreSQL setups which are shared with other services, follow these backup and restore guidelines.
Limited Snap backup
Identify the MAAS database that you want to back up:
sudo -u postgres psql \l # identifying the MAAS database is up to you \q
sudo -u postgres pg_dump [maas_database_name] > "<external-backup-media>/maas-backups/<backup-timestamp>/$(date +%s)_maas_only_backup.sql"
Stop MAAS:
sudo snap stop maas
sudo snap save maas
Restart MAAS:
Limited Snap restore
sudo snap stop maas
Do a limited restore of the MAAS database only:
sudo -u postgres psql [maas_database_name] < <external-backup-media>/maas-backups/<backup-timestamp>/<dump_epoch>_maas_only_backup.sql
Restart MAAS:
Limited package backup
Stop MAAS services:
Restart MAAS:
Limited package restore
Untar the MAAS backup to a temporary directory:
backup_dir="/var/backups/maas_backup/$(date +%s)" sudo mkdir -p "$backup_dir"
sudo mv /etc/maas "$backup_dir/etc_maas" sudo mv /var/lib/maas "$backup_dir/var_lib_maas"
Remove the current MAAS installation
sudo apt-get remove --purge maas sudo apt-get autoremove
sudo cp -prf /tmp/maas_backup/etc/maas /etc/ sudo cp -prf /tmp/maas_backup/var/lib/maas /var/lib/
