I am attempting to contribute to maas and am working on fixing some tests. I am doing my development on a vagrant box with the following vagrant file
Vagrant.configure('2') do |config|
config.vm.box = 'bento/ubuntu-18.04'
config.vm.provision 'shell', inline: <<-SHELL
cd /vagrant
sudo apt-get update
make install-dependencies
./utilities/configure-lxd-profile
SHELL
end
The HACKING.rst document specifies that individual tests can be run by passing ./bin/test.region path/to/test/file
However, when I run the following, every test fails with a twisted.internet.error.ReactorAlreadyRunning error
vagrant@vagrant:/vagrant$ ./bin/test.region src/provisioningserver/drivers/power/tests/test_redfish.py
ERROR: provisioningserver.drivers.power.tests.test_redfish.TestRedfishPowerDriver.test_redfish_request_retries_404s_trailing_slash
File "/usr/lib/python3/dist-packages/nose/case.py", line 133, in run
self.runTest(result)
File "/usr/lib/python3/dist-packages/nose/case.py", line 151, in runTest
test(result)
File "/vagrant/src/maastesting/testcase.py", line 279, in __call__
super(MAASTestCase, self).__call__(result)
File "/vagrant/src/maastesting/scenarios.py", line 34, in __call__
super(WithScenarios, self).__call__(result)
File "/home/vagrant/.buildout/eggs/unittest2-1.1.0-py3.6.egg/unittest2/case.py", line 673, in __call__
return self.run(*args, **kwds)
File "/vagrant/src/maastesting/testcase.py", line 275, in run
super(MAASTestCase, self).run(result)
File "/home/vagrant/.buildout/eggs/testscenarios-0.5.0-py3.6.egg/testscenarios/testcase.py", line 65, in run
return super(WithScenarios, self).run(result)
File "/home/vagrant/.buildout/eggs/testtools-2.2.0-py3.6.egg/testtools/testcase.py", line 671, in run
return run_test.run(result)
File "/home/vagrant/.buildout/eggs/testtools-2.2.0-py3.6.egg/testtools/runtest.py", line 80, in run
return self._run_one(actual_result)
File "/home/vagrant/.buildout/eggs/testtools-2.2.0-py3.6.egg/testtools/runtest.py", line 94, in _run_one
return self._run_prepared_result(ExtendedToOriginalDecorator(result))
File "/home/vagrant/.buildout/eggs/testtools-2.2.0-py3.6.egg/testtools/runtest.py", line 108, in _run_prepared_result
self._run_core()
File "/home/vagrant/.buildout/eggs/testtools-2.2.0-py3.6.egg/testtools/twistedsupport/_runtest.py", line 432, in _run_core
spinner)
File "/home/vagrant/.buildout/eggs/testtools-2.2.0-py3.6.egg/testtools/twistedsupport/_runtest.py", line 393, in _blocking_run_deferred
spinner.run, self._timeout, self._run_deferred)
File "/home/vagrant/.buildout/eggs/testtools-2.2.0-py3.6.egg/testtools/twistedsupport/_spinner.py", line 77, in trap_unhandled_errors
result = function(*args, **kwargs)
File "/home/vagrant/.buildout/eggs/testtools-2.2.0-py3.6.egg/testtools/twistedsupport/_spinner.py", line 49, in decorated
return function(*args, **kwargs)
File "/home/vagrant/.buildout/eggs/testtools-2.2.0-py3.6.egg/testtools/twistedsupport/_spinner.py", line 295, in run
self._reactor.run()
File "/usr/lib/python3/dist-packages/twisted/internet/asyncioreactor.py", line 266, in run
self.startRunning(installSignalHandlers=installSignalHandlers)
File "/usr/lib/python3/dist-packages/twisted/internet/base.py", line 1222, in startRunning
ReactorBase.startRunning(self)
File "/usr/lib/python3/dist-packages/twisted/internet/base.py", line 728, in startRunning
raise error.ReactorAlreadyRunning()
These tests do not fail with this error when running make test. Is there some additional setup needed in order to run the granular tests? It would really speed up my iteration time.
