Hello, everyone.
I have a set of servers with small SSDs which I use for booting and an iSCSI NAS that I would like to use as the main storage for the VMs that will run on the hosts.
Attaching the storage from the OS after Deployment never updates the discovered storage in MAAS (there are a number of posts that speak to that). My question is - what is the recommended way to handle this? When does the storage configuration gets ‘baked in’? Is it during Comissioning? Can I use a post-deployment script?
Thanks in advance.
