API authentication reference (snap/3.1/CLI)
The MAAS API uses OAuth as its authentication mechanism. This isn’t third-party (3-legged) OAuth, so the process used is what’s commonly referred to as 0-legged OAuth: the consumer accesses protected resources by submitting OAuth signed requests.
Note that some API endpoints support unauthenticated requests (i.e. anonymous access). See the API documentation for details.
Two questions you may have:
  1. How can I perform authenticated requests in python?
  2. How can I perform authenticated requests in ruby?
Here are two examples on how to perform an authenticated GET request to retrieve the list of nodes. The <key>, <secret>, <consumer_key> tokens are the three elements that compose the API key (API key = ‘<consumer_key>:<key>:<secret>’).
Python
import oauth.oauth as oauth
import httplib2
import uuid
def perform_API_request(site, uri, method, key, secret, consumer_key):
    resource_tok_string = "oauth_token_secret=%s&oauth_token=%s" % (
        secret, key)
    resource_token = oauth.OAuthToken.from_string(resource_tok_string)
    consumer_token = oauth.OAuthConsumer(consumer_key, "")
    oauth_request = oauth.OAuthRequest.from_consumer_and_token(
        consumer_token, token=resource_token, http_url=site,
        parameters={'oauth_nonce': uuid.uuid4().hex})
    oauth_request.sign_request(
        oauth.OAuthSignatureMethod_PLAINTEXT(), consumer_token,
        resource_token)
    headers = oauth_request.to_header()
    url = "%s%s" % (site, uri)
    http = httplib2.Http()
    return http.request(url, method, body=None, headers=headers)
# API key = '<consumer_key>:<key>:<secret>'
response = perform_API_request(
    'http://server/MAAS/api/1.0', '/nodes/?op=list', 'GET', '<key>', '<secret>',
    '<consumer_key>')
Ruby
require 'oauth'
require 'oauth/signature/plaintext'
def perform_API_request(site, uri, key, secret, consumer_key)
    consumer = OAuth::Consumer.new(
        consumer_key, "",
        { :site => "http://localhost/MAAS/api/1.0",
          :scheme => :header, :signature_method => "PLAINTEXT"})
    access_token = OAuth::AccessToken.new(consumer, key, secret)
    return access_token.request(:get, "/nodes/?op=list")
end
# API key = "<consumer_key>:<key>:<secret>"
     "http://server/MAAS/api/1.0", "/nodes/?op=list", "<key>", "<secret>",
     "consumer_key>")
