<script>
// Set up scene, camera, renderer
const scene = new THREE.Scene();
scene.background = new THREE.Color(0xf2f2f2); // Ghostly light gray background color
const camera = new THREE.PerspectiveCamera(75, window.innerWidth / window.innerHeight, 0.1, 1000);
const renderer = new THREE.WebGLRenderer();
renderer.setSize(window.innerWidth, window.innerHeight);
document.body.appendChild(renderer.domElement);
// Utility to create text label as a sprite
function createTextSprite(message, x, y, z, widthFactor = 1.0) {
const canvas = document.createElement('canvas');
canvas.width = 500;
canvas.height = 200;
const context = canvas.getContext('2d');
context.font = 'bold 48px Arial'; // Normal text size
context.fillStyle = 'black'; // Black text color
context.textAlign = 'center';
context.textBaseline = 'middle';
context.fillText(message, canvas.width / 2, canvas.height / 2);
const texture = new THREE.CanvasTexture(canvas);
const spriteMaterial = new THREE.SpriteMaterial({ map: texture });
const sprite = new THREE.Sprite(spriteMaterial);
// Scale sprite width according to the width factor (for centering over the box width)
sprite.scale.set(widthFactor, 2.0, 2); // Proportional height for normal text appearance
sprite.position.set(x, y, z);
scene.add(sprite);
// Create NIC box
function createNICBox(x, y, z) {
const nicGroup = new THREE.Group();
// NIC base box (darker gray)
const boxGeometry = new THREE.BoxGeometry(1.8, 0.5, 0.5); // Wider NIC box
const darkGrayMaterial = new THREE.MeshBasicMaterial({ color: 0xb0b0b0 }); // Darker gray fill
const nicBox = new THREE.Mesh(boxGeometry, darkGrayMaterial);
nicGroup.add(nicBox);
// Green indicator circle (always on)
const greenCircleGeometry = new THREE.CircleGeometry(0.15, 32);
const greenMaterial = new THREE.MeshBasicMaterial({ color: 0x00ff00 });
const greenCircle = new THREE.Mesh(greenCircleGeometry, greenMaterial);
greenCircle.position.set(-0.2, 0.0, 0.26); // Bottom left of NIC box
nicGroup.add(greenCircle);
// Black status circle (turns yellow later)
const blackCircleGeometry = new THREE.CircleGeometry(0.15, 32);
const blackMaterial = new THREE.MeshBasicMaterial({ color: 0x000000 });
const blackCircle = new THREE.Mesh(blackCircleGeometry, blackMaterial);
blackCircle.position.set(-0.6, 0.0, 0.26); // Slightly to the left of the green circle
nicGroup.add(blackCircle);
nicGroup.position.set(x, y, z);
scene.add(nicGroup);
// Add "NIC" label (half the width of the NIC box)
createTextSprite('NIC', x - 0.5, y + 0.45, z, 4.0); // NIC label centered with half-width
return { nicGroup, blackCircle };
// Function to create a server box with vents and lamp
function createServerBox(x, y, z, label, lampAlwaysGreen) {
const boxGroup = new THREE.Group();
// Outer box (gray)
const boxWidth = 1.5;
const outerGeometry = new THREE.BoxGeometry(boxWidth, 1, 1);
const outerMaterial = new THREE.MeshBasicMaterial({ color: 0x666666 });
const outerBox = new THREE.Mesh(outerGeometry, outerMaterial);
// On-lamp
const lampGeometry = new THREE.BoxGeometry(0.3, 0.1, 0.01);
const lampColor = lampAlwaysGreen ? 0x00ff00 : 0x003300;
const lampMaterial = new THREE.MeshBasicMaterial({ color: lampColor });
const lamp = new THREE.Mesh(lampGeometry, lampMaterial);
lamp.position.set(0, -0.4, 0.51); // Slightly outside the front face
// Vent lines
const ventGroup = new THREE.Group();
const ventMaterial = new THREE.MeshBasicMaterial({ color: 0x000000 });
for (let i = -0.6; i <= 0.6; i += 0.2) {
const ventGeometry = new THREE.BoxGeometry(0.05, 0.8, 0.01);
const vent = new THREE.Mesh(ventGeometry, ventMaterial);
vent.position.set(i, 0, 0.51);
ventGroup.add(vent);
boxGroup.add(outerBox);
boxGroup.add(ventGroup);
boxGroup.add(lamp);
boxGroup.position.set(x, y, z);
scene.add(boxGroup);
// Add label centered and closer to the server box
const widthFactor = label === "NIC" ? 1.5 : 5.0; // Width factor for normal labels
createTextSprite(label, x, y + 0.85, z, widthFactor); // Centered and proportional text
return { boxGroup, lamp };
const maasServer = createServerBox(-3, 0, 0, "MAAS", true); // MAAS always green
const machineServer = createServerBox(3, 0, 0, "Machine", false); // Machine starts off
const nicBox = createNICBox(2.1, 0, 0); // NIC positioned closer and wider
// Wire between MAAS and NIC
const wireGeometry = new THREE.CylinderGeometry(0.05, 0.05, 5.6);
const wireMaterial = new THREE.MeshBasicMaterial({ color: 0x444444 });
const wire = new THREE.Mesh(wireGeometry, wireMaterial);
wire.rotation.z = Math.PI / 2;
wire.position.set(-0.5, 0, 0);
scene.add(wire);
// Pulse (sphere representing data transfer)
const pulseGeometry = new THREE.SphereGeometry(0.15, 32, 32);
const pulseMaterial = new THREE.MeshBasicMaterial({ color: 0xFFCC00 });
const pulse = new THREE.Mesh(pulseGeometry, pulseMaterial);
pulse.position.set(-3, 0, 0); // Start at MAAS
scene.add(pulse);
camera.position.z = 8;
// Function to update the pulse position and status lights
let nicGreen = false;
let machineGreen = false;
function updatePulsePosition(value) {
const startX = -3;
const endX = 2.1;
const newX = startX + (value / 100) * (endX - startX);
pulse.position.x = newX;
// Turn NIC status light yellow when pulse arrives
if (newX >= 1.4) {
nicBox.blackCircle.material.color.setHex(0xFFCC00); // Yellow status light
nicGreen = true;
// Turn Machine lamp green after 1 second
setTimeout(() => {
machineServer.lamp.material.color.setHex(0x00ff00); // Green Machine lamp
machineGreen = true;
}, 1000);
// Slider listener
const slider = document.getElementById('slider');
slider.addEventListener('input', (event) => {
updatePulsePosition(event.target.value);
// Render loop
function animate() {
requestAnimationFrame(animate);
renderer.render(scene, camera);
animate();
window.addEventListener('resize', () => {
camera.aspect = window.innerWidth / window.innerHeight;
camera.updateProjectionMatrix();
</script>
MAAS to Machine with NIC Status Indicators
body { margin: 0; }
canvas { display: block; }
.slider-container {
position: absolute;
bottom: 370px;
left: 50%;
transform: translateX(-50%);
width: 40%;
