Hi all,
To be honest I think it is a bug, I am trying to add an lxd cluster via maas cli, I am issuing command
maas admin vm-hosts create -d type=lxd power_address=lxdbr0_address:8443 password=mysecretpwproject=juju name=lxd3 pool=default
It results in
200 OK
Connection: keep-alive
Content-Length: 1013
Content-Type: application/json; charset=utf-8
Date: Sun, 06 Nov 2022 18:59:23 GMT
Server: nginx/1.18.0 (Ubuntu)
Status: 200
Vary: Authorization, Cookie
X-Frame-Options: DENY
X-Maas-Api-Hash: c5fad5a4a9e2cd2fb3fe98dcdcea34706905f6b8
"tags": [
"pod-console-logging"
"host": {
"system_id": null,
"__incomplete__": true
"zone": {
"name": "default",
"description": "",
"id": 1,
"architectures": [],
"capabilities": [],
"pool": {
"name": "default",
"id": 0,
"type": "lxd",
"total": {
"cores": 0,
"memory": 0,
"local_storage": 0
"id": 18,
"available": {
"cores": 0,
"memory": 0,
"local_storage": 0
"storage_pools": [],
"used": {
"cores": 0,
"memory": 0,
"local_storage": 0
"default_macvlan_mode": null,
"cpu_over_commit_ratio": 1.0,
"version": "",
"name": "lxd3",
"resource_uri": "/MAAS/api/2.0/vm-hosts/18/"
Maas is inside an lxd container in that host, the connectivity is there
ping 10.10.11.13
PING 10.10.11.13 (10.10.11.13) 56(84) bytes of data.
64 bytes from 10.10.11.13: icmp_seq=1 ttl=63 time=0.372 ms
64 bytes from 10.10.11.13: icmp_seq=2 ttl=63 time=0.357 ms
64 bytes from 10.10.11.13: icmp_seq=2 ttl=63 time=0.396 ms (DUP!)
^C
telnet 10.10.11.13 8443
Trying 10.10.11.13...
Connected to 10.10.11.13.
Escape character is '^]'.
Unfortunately every time the outcome is
0 resources
I can see the problem being discussed in
But I wonder which conf files the author @minhoryang meant
In my environment there is a snap installation.
How can one investigate it further?
