So fresh LXD install and MaaS install (same node).
Lxd is using a zfs backend for default storage. When I add it to MaaS via the gui, it shows up, but there is zero storage seen, even though it is several terrabytes.
If I try to ‘refresh’ the host, I get “Failed talking to pod: Not Found”
It was working fine and then I did a wipe/reinstall. That was so I could get the practice and set up MaaS to use a bonded interface. I am able to use lxc and create vms no issue, just can’t do anything via MaaS.
Anyone have insight for troubleshooting?
