I have a MAAS with 7 machines deployed up and running for one year with version: 2.8.7. The MAAS hosted machine went into bad sector disk issue reently so the file system change to read only mode.
I can only manage to extract the data under /snap/maas/current/etc/maas and /var/snap/maas/common/maas but failed to back up the Postgre maas-test-db…
and I have installed a new ubuntu 20.04 environment with MAAS 2.8.7… seems the files under /snap/maas/currrent/etc/maas and var/snap/maas/common/maas are not enough to recover the maas. Is there a way that I can add back my old deployed machine under old MAAS to my new MAAS within the same network?
I have been searching for a week and tried method like adding the dhcpd.conf host info to dhcpd.conf with MAAS web interface but it does not work.
Hope anyone here can give me some idea. Thanks…
