Add ability to remove failed tests
Currently there is no clean method for removing failed tests or their results. For instance, if a long running badblocks-destructive test times out, said node will be forever marked as having a failed test. Similar thing applies to tests that are skipped, such as smartctl-validate test bailing out on a hardware raid array.
While re-running a test is sometimes an option, other times (such as smartctl-validate) it will always fail. A given node is then marked forever as potentially problematic.
It would be great to have a menu option that would allow for simply removing a given test history/results/etc, and consequently show a fully working node.
Thanks!
Thanks for the feedback. You may already know this, but (as a workaround) you can browse to the node in the Web UI and select Override failed testing from the menu to allow the node to be used.
I agree it might be nice to delete known-to-fail test results in some cases. I’ve seen this issue in heavily-firewalled environments with the internet connectivity tests.
Thanks! Unfortunately ā€˜override failed testing’ seems to be available only under specific conditions. For example, see how it doesn’t appear in any context menus here:
https://imgur.com/a/yVC8HQ7
Thanks; that looks like a bug. If you could file a bug on that, that would be appreciated.
For the record, (on the MAAS I’m testing on now) I was able to find the option from the machine listing (but not on a specific machine - but I don’t have any in Failed Testing state at the moment).
Edit: My mistake; I didn’t notice the machine was still in ā€œReadyā€ state. I still think your idea is good, but I agree with Andres that it is not a bug.
Thank you for your help. New bug filed as https://bugs.launchpad.net/maas/+bug/1786468
This is actually not a bug. The ā€˜Override failed testing’ is an action only available when the machine is in ā€˜Failed testing’ state, and not when the machine is in ā€˜Ready’ state.
Please note that such action will not make failed tests (or icons) disappear. The action is intended to allow the user to use a machine that has had failed tests. That said, since the machine failed testing anyway, MAAS will continue to show the error icons because the machine never actually passed the tests.
The only way to make those icons disappear is if the tests are re-run and they complete successfully.
Thank you for clarification. Perhaps the wording behind ā€˜Override Failed …’ menu option led me to believe it would clear individual tests.
This brings the discussion full circle to the original point: creating ability to clear individual tests, without having to re-run them. Something like badblocks-destructive on a larger storage subsystem can take significant amount of time, and often is not necessary to repeat.
Please note that all actions in the action menu affect to machines as a whole, and not sections inside a machine. e.g.:
Actions - you have action to deploy, release, power on, power off, etc.
But if you want to add interfaces, change settings, etc, that’s done inline.
That said, you can use the API to delete test runs, but again, we discourage it provided that if a test fail, it is a big indication that’s something wrong with the machine and you are using it with a risk. Either way, you can delete the results for a machine with something like:
maas < user > node-script-result delete < machine system_id > < id of the result entry >
You can list all results for a machine with:
maas < user > node-script-results read < machine system_id >
It really would be good to be able to make the icons go away sometimes.
For instance, SMARTS tests reports all errors that the disk drive has seen, which is not the same as all errors that have occurred on the disk drive. I have some drives with communications errors in their SMARTS logs because of faulty SATA cables. I’ve replaced the cables, but now I’m stuck with a permanent alert in MAAS. I’ve also seen problems with Dell hot-plug SAS backplanes.
On the other hand, I’m very happy to have SMARTS media errors stick around in the MAAS display. I’ve got a few of them too and having them drowned by false alarms isn’t good. I might have to think more about what can be done with the information from SMARTS.
Cheers,
Lloyd
After you changed the cable, would smarctl now say that the error is fixed, but since there were previous errors it still returns a non-zero return code?
That’s the gist of it.
I’ve reviewed the smartctl logs and I did misread the PHY error logs. I assumed they were errors because I’ve had problems with SATA cables, but the PHY error logs are counters and all the counts are zero.
The actual problem I had in the past was drives overheating (not by much). The exit code from smartctl has bit 5 set to indicate that the drive is fine now, but something bad happened in the past. smartctl can also set bit 2 when it issues a command that doesn’t work.
I think that divining exactly what triggers all the bits in the smartctl exit status could be a bit of a black art. On the other hand, if you want a variety of dodgy hard drives to run sample code against, I can help.
Here is the output from one of my disks, complete with genuine spelling mistake on line 1.
smartctl with exit status 32
INFO: Veriying SMART support for the following drive: /dev/sde
INFO: Running command: sudo -n smartctl --all /dev/sdeI
INFO: SMART support is available; continuing...I
INFO: Verifying and/or validating SMART tests...I
INFO: Running command: sudo -n smartctl --xall /dev/sdeI
FAILURE: SMART tests have FAILED for: /dev/sdeF
The test exited with return code 32! See the smarctl manpage for information on the return code meaning. For more information on the test failures, review the test output provided below.T
smartctl 6.5 2016-01-24 r4214 [x86_64-linux-4.4.0-128-generic] (local build)s
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.orgC
=== START OF INFORMATION SECTION ====
Model Family:     Seagate NAS HDDM
Device Model:     ST4000VN000-1H4168D
Serial Number:    Z300QPXZS
LU WWN Device Id: 5 000c50 0645cd965L
Firmware Version: SC43F
User Capacity:    4,000,787,030,016 bytes [4.00 TB]U
Sector Sizes:     512 bytes logical, 4096 bytes physicalS
Rotation Rate:    5900 rpmR
Form Factor:      3.5 inchesF
Device is:        In smartctl database [for details use: -P show]D
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3bA
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)S
Local Time is:    Tue Jun 19 08:28:15 2018 UTCL
SMART support is: Available - device has SMART capability.S
SMART support is: EnabledS
AAM feature is:   UnavailableA
APM level is:     254 (maximum performance)A
Rd look-ahead is: EnabledR
Write cache is:   EnabledW
ATA Security is:  Disabled, frozen [SEC2]A
Wt Cache Reorder: EnabledW
=== START OF READ SMART DATA SECTION ====
SMART overall-health self-assessment test result: PASSEDS
See vendor-specific Attribute list for marginal Attributes.S
General SMART Values:G
Offline data collection status:  (0x82)	Offline data collection activityO
					was completed without error.
Self-test execution status:      (   0)	The previous self-test routine completedS
					been run.
Total time to complete Offline T
data collection: 		(  107) seconds.d
Offline data collectionO
capabilities: 			 (0x7b) SMART execute Offline immediate.c
					Auto Offline data collection on/off support.
					command.
					Self-test supported.
					Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before enteringS
					power-saving mode.
Error logging capability:        (0x01)	Error logging supported.E
					General Purpose Logging supported.
Short self-test routine S
recommended polling time: 	 (   1) minutes.r
Extended self-test routineE
recommended polling time: 	 ( 510) minutes.r
Conveyance self-test routineC
recommended polling time: 	 (   2) minutes.r
SCT capabilities: 	       (0x10bd)	SCT Status supported.S
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 10S
Vendor Specific SMART Attributes with Thresholds:V
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUEI
  1 Raw_Read_Error_Rate     POSR--   118   099   006    -    187129512
  3 Spin_Up_Time            PO----   092   091   000    -    0
  4 Start_Stop_Count        -O--CK   085   085   020    -    15853
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0
  7 Seek_Error_Rate         POSR--   078   060   030    -    68242999
  9 Power_On_Hours          -O--CK   080   080   000    -    18296
 10 Spin_Retry_Count        PO--C-   100   100   097    -    0
 12 Power_Cycle_Count       -O--CK   099   099   020    -    1068
184 End-to-End_Error        -O--CK   100   100   099    -    01
187 Reported_Uncorrect      -O--CK   100   100   000    -    01
188 Command_Timeout         -O--CK   100   099   000    -    85900656661
189 High_Fly_Writes         -O-RCK   001   001   000    -    7031
190 Airflow_Temperature_Cel -O---K   075   043   045    Past 25 (0 6 25 24 0)1
191 G-Sense_Error_Rate      -O--CK   100   100   000    -    01
192 Power-Off_Retract_Count -O--CK   100   100   000    -    8931
193 Load_Cycle_Count        -O--CK   092   092   000    -    165861
194 Temperature_Celsius     -O---K   025   057   000    -    25 (0 9 0 0 0)1
197 Current_Pending_Sector  -O--C-   100   100   000    -    01
198 Offline_Uncorrectable   ----C-   100   100   000    -    01
199 UDMA_CRC_Error_Count    -OSRCK   200   200   000    -    01
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1G
SMART           Log Directory Version 1 [multi-sector log support]S
Address    Access  R/W   Size  DescriptionA
0x00       GPL,SL  R/O      1  Log Directory0
0x01           SL  R/O      1  Summary SMART error log0
0x02           SL  R/O      5  Comprehensive SMART error log0
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log0
0x06           SL  R/O      1  SMART self-test log0
0x07       GPL     R/O      1  Extended self-test log0
0x09           SL  R/W      1  Selective self-test log0
0x10       GPL     R/O      1  SATA NCQ Queued Error log0
0x11       GPL     R/O      1  SATA Phy Event Counters log0
0x21       GPL     R/O      1  Write stream error log0
0x22       GPL     R/O      1  Read stream error log0
0x24       GPL     R/O   1223  Current Device Internal Status Data log0
0x25       GPL     R/O   1223  Saved Device Internal Status Data log0
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log0
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log0
0xa1       GPL,SL  VS      20  Device vendor specific log0
0xa2       GPL     VS    4496  Device vendor specific log0
0xa8       GPL,SL  VS     129  Device vendor specific log0
0xa9       GPL,SL  VS       1  Device vendor specific log0
0xab       GPL     VS       1  Device vendor specific log0
0xb0       GPL     VS    5176  Device vendor specific log0
0xbe-0xbf  GPL     VS   65535  Device vendor specific log0
0xc1       GPL,SL  VS      10  Device vendor specific log0
0xc3       GPL,SL  VS       8  Device vendor specific log0
0xc4       GPL,SL  VS       5  Device vendor specific log0
0xe0       GPL,SL  R/W      1  SCT Command/Status0
0xe1       GPL,SL  R/W      1  SCT Data Transfer0
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)S
No Errors LoggedN
SMART Extended Self-test Log Version: 1 (1 sectors)S
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_errorN
# 1  Short offline       Aborted by host               90%      9842         -#
# 2  Short offline       Aborted by host               90%      9841         -#
# 3  Short offline       Aborted by host               90%      9841         -#
# 4  Short offline       Aborted by host               90%      9841         -#
# 5  Short offline       Aborted by host               90%      9841         -#
# 6  Short offline       Aborted by host               90%      9841         -#
# 7  Short offline       Aborted by host               90%      9841         -#
# 8  Short offline       Aborted by host               90%      9841         -#
# 9  Short offline       Aborted by host               90%      9841         -#
#10  Short offline       Aborted by host               90%      7716         -#
#11  Short offline       Aborted by host               90%      7716         -#
#12  Short offline       Aborted by host               90%      7716         -#
#13  Short offline       Aborted by host               90%      7716         -#
#14  Short offline       Aborted by host               90%      7716         -#
#15  Short offline       Aborted by host               90%      7716         -#
#16  Short offline       Aborted by host               90%      6903         -#
#17  Short offline       Aborted by host               90%      6903         -#
#18  Short offline       Aborted by host               90%      6903         -#
#19  Short offline       Aborted by host               90%      6903         -#
SMART Selective self-test log data structure revision number 1S
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):S
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.I
SCT Status Version:                  3S
SCT Version (vendor specific):       522 (0x020a)S
SCT Support Level:                   1S
Device State:                        Active (0)D
Current Temperature:                    25 CelsiusC
Power Cycle Min/Max Temperature:     24/25 CelsiusP
Lifetime    Min/Max Temperature:      9/56 CelsiusL
Under/Over Temperature Limit Count:   0/0U
SCT Temperature History Version:     2S
Temperature Sampling Period:         1 minuteT
Temperature Logging Interval:        94 minutesT
Min/Max recommended Temperature:      1/61 CelsiusM
Min/Max Temperature Limit:            2/60 CelsiusM
Temperature History Size (Index):    128 (74)T
Index    Estimated Time   Temperature CelsiusI
  75    2018-06-11 00:28    26  *******
  76    2018-06-11 02:02    25  ******
 ...    ..(  2 skipped).    ..  ******
  79    2018-06-11 06:44    25  ******
  80    2018-06-11 08:18    26  *******
  81    2018-06-11 09:52    25  ******
  82    2018-06-11 11:26    26  *******
  83    2018-06-11 13:00    26  *******
  84    2018-06-11 14:34    26  *******
  85    2018-06-11 16:08    25  ******
 ...    ..(  9 skipped).    ..  ******
  95    2018-06-12 07:48    25  ******
  96    2018-06-12 09:22    26  *******
 ...    ..( 44 skipped).    ..  *******
  13    2018-06-15 07:52    26  *******
  14    2018-06-15 09:26    27  ********
 ...    ..(  8 skipped).    ..  ********
  23    2018-06-15 23:32    27  ********
  24    2018-06-16 01:06    26  *******
 ...    ..(  6 skipped).    ..  *******
  31    2018-06-16 12:04    26  *******
  32    2018-06-16 13:38    25  ******
  35    2018-06-16 18:20    25  ******
  36    2018-06-16 19:54    26  *******
 ...    ..(  5 skipped).    ..  *******
  42    2018-06-17 05:18    26  *******
  43    2018-06-17 06:52    27  ********
 ...    ..(  2 skipped).    ..  ********
  46    2018-06-17 11:34    27  ********
  47    2018-06-17 13:08    26  *******
 ...    ..( 17 skipped).    ..  *******
  65    2018-06-18 17:20    26  *******
  66    2018-06-18 18:54    25  ******
  72    2018-06-19 04:18    25  ******
  73    2018-06-19 05:52     ?  -
  74    2018-06-19 07:26    24  *****
SCT Error Recovery Control:S
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supportedD
SATA Phy Event Counters (GP Log 0x11)S
ID      Size     Value  DescriptionI
0x000a  2            6  Device-to-host register FISes sent due to a COMRESET0
0x0001  2            0  Command failed due to ICRC error0
0x0003  2            0  R_ERR response for device-to-host data FIS0
0x0004  2            0  R_ERR response for host-to-device data FIS0
0x0006  2            0  R_ERR response for device-to-host non-data FIS0
0x0007  2            0  R_ERR response for host-to-device non-data FIS0
Is there any way to get rid of the ā€œBit: 5ā€ warmings (error code 32) ?
I’m trying to get rid of these warnings when commissioning some old servers in MAAS… After all, I don’t care about old errors…
190 Airflow_Temperature_Cel 0x0022 072 029 045 Old_age Always In_the_past 28 (0 9 28 24 0)
