Add a machine which is already running and get information
I’m using machines with ubuntu on them. I have found on your web site that it’s possible to add a machine which is already running with maas-run-scripts but after the success of them, I can’t do any actions. Indeed, I can release the machine but after I can only allocate it but I can’t commission or deploy it. Moreover, when I modify the network configuration, all disappear when I release the machine.
Is there a way to edit those scripts or some actions to do to have all the machines information (such as IP addresses, interfaces, power type…) by adding the machine without reboot it, commissioning it and deploying it?
Hey,
Does this work for you https://maas.io/docs/reference-release-notes-maas-3-1#p-11417-how-to-update-hardware-information-for-a-deployed-machine ?
