- machines (physical and virtual)
- VM hosts
- controllers (rack and region)
- storage (virtual and physical; block devices or partitions)
- network interfaces
- devices
- nodes (in the CLI only)
- Work with tags in general
- Work with machine and VM tags
- Work with controller tags
- Work with block device tags
- Work with partition tags
- Work with network tags
- Work with device tags
- Work with node tags (CLI only)
Work with tags
This section is devoted to procedures for working with tags. We begin with some general operations that apply to all tags types, such as naming conventions and basic mechanics. We then walk through the various tag types, providing procedures that will help you create, assign, remove, delete, list, view, and filter tags, covering the nuances of each type.
- Work with tags, independent of application
- Work with machine tags
- Work with virtual machine host tags
- Work with region controller tags
- Work with rack controller tags
This subsection will explain how to:
- Create a tag
- Create tags with built-in kernel options
- Delete a tag
- Update a tag
- List all tags available on this MAAS
- Rebuild a tag
Create a tag
"name": "new_tag",
"definition": "",
"kernel_opts": "",
For example:
"name": "nomodeset_tag",
"definition": "",
| @tsv' | column -t
tag_name tag_comment kernel_options
virtual
new_tag a-new-tag-for-test-purposes
pod-console-logging console=tty1 console=ttyS0
nomodeset_tag nomodeset_kernel_option nomodeset vga
Delete a tag
maas admin tag delete zorko
Update a tag
For example:
"name": "new_tag",
"definition": "",
"kernel_opts": "",
For example:
virtual
Rebuild a tag
"rebuilding": "virtual"
- Assign machine tags to a machine
- Remove machine tags from a machine
- List machine tags for all machines
- View machine tags for one machine
Note: Adding tags to machines does not automatically create the tags. Tags must exist before they are added to machines.
For example:
"added": 1,
"removed": 0
| @tsv' | column -t
hostname sysid machine_tags
divine-stork 8b3ypp pod-console-logging virtual
casual-prawn 4end6r pod-console-logging virtual
driven-teal tgaat6 pod-console-logging virtual
immune-beetle 43xand pod-console-logging virtual
good-osprey napfxk pod-console-logging virtual
smart-hen c4rwq7 pod-console-logging virtual
boss-satyr xn8taa pod-console-logging androko
golden-martin 8fxery pod-console-logging virtual
crack-guinea qk4b3g pod-console-logging virtual
finer-leech cy3dtr pod-console-logging virtual
free-mouse gxtbq4 pod-console-logging virtual
humble-bunny srqnnb pod-console-logging virtual
wanted-muskox ekw7fh pod-console-logging virtual
one-boa by477d pod-console-logging virtual
great-urchin srnx4g pod-console-logging virtual
ace-frog g6arwg pod-console-logging virtual barbar farquar new_tag
alive-marlin gbwnfb pod-console-logging virtual
picked-parrot am77wn pod-console-logging virtual
tough-kit ke3wc7 pod-console-logging virtual
legal-whale 8nq3mt pod-console-logging virtual
game-sponge 76pdc6 pod-console-logging virtual
fun-ghoul qxfm7k pod-console-logging virtual
aware-earwig 8m8hs7 pod-console-logging virtual
chief-crane 7fapx7 pod-console-logging virtual
select-tapir 4ascbr pod-console-logging virtual
on-slug snfs8d pod-console-logging virtual
polite-llama dbqd4m pod-console-logging virtual
frank-coyote wcmk48 pod-console-logging virtual
usable-condor ed8hmy pod-console-logging virtual
still-imp h6ra6d pod-console-logging virtual
For example:
"added": 0,
"removed": 1
Adding and removing machine tags simultaneously from multiple machines
"added": 2,
"removed": 1
| @tsv' | column -t
golden-martin 8fxery pod-console-logging virtual barbar
one-boa by477d pod-console-logging virtual barbar
ace-frog g6arwg pod-console-logging virtual farquar
For example:
| @tsv' | column -t
For example:
| @tsv' | column -t
- Discover your virtual machine host ID
- Assign tags to a virtual machine host
- Remove tags from a virtual machine
- List tags for all virtual machines
- View tags for one virtual machine
maas $PROFILE vmhosts read \
| @tsv' | column -t
For example:
maas admin vmhosts read \
| @tsv' | column -t
vm_host_name id
my-lxd-vm-host-1 1
maas $PROFILE vmhost add-tag $VMHOST_ID tag=$TAG_NAME
If it worked, this should return Success, followed by the JSON that describes the VM host. You can check your work by listing all VM host tags.
Remove tags from a virtual machine host
List tags for all virtual machine hosts
For example:
vm_host_name id tags
my-lxd-vm-host-1 1 morkopongo pod-console-logging virtual
View tags for one virtual machine host
| @tsv' | column -t
name id tags
- Discover the ID of your region controller(s)
- Assign tags to a region controller
- Remove tags from a region controller
- List tags for all region controllers
- View tags for one region controller
| jq -r '(["name","id"]
| @tsv' | column -t
For example:
| @tsv' | column -t
name id
bill-Lenovo-Yoga-C740-15IML 86xya8
For example:
"added": 1,
"removed": 0
For example:
"added": 0,
"removed": 1
For example:
hostname sysid tags
bill-Lenovo-Yoga-C740-15IML 86xya8 virtual lxd-vm-host
If you need to find the ID of your region controller(s), you can [look it up](#heading--discover-the-id-of-your-region-controllers).
For example:
```bash
| @tsv' | column -t
hostname sysid tags
- Discover the ID of your rack controller(s)
- Assign tags to a rack controller
- Remove tags from a rack controller
- List tags for all rack controllers
- View tags for one rack controller
| @tsv' | column -t
For example:
| @tsv' | column -t
name id
For example:
"added": 1,
"removed": 0
For example:
"added": 0,
"removed": 1
For example:
hostname sysid tags
For example:
```bash
| @tsv' | column -t
hostname sysid tags
- Discover the ID of your block device
- Assign tags to a block device
- Remove tags from a block device
- List tags for all block devices
- View tags for one block device
| @tsv' | column -t
For example:
| @tsv' | column -t
system_id block_device_id path avail_size
qk4b3g 10 /dev/disk/by-dname/sda 0
The path component is printed to help you confirm that you are choosing the right block device, when there are several present. The avail-size column will tell you whether you can operate on that block device at all: If the available size is “0,” for example, you can’t set a block device tag on any part of that drive. Instead, you’d want to see something like this:
xn8taa 8 /dev/disk/by-dname/sda 1996488704
For example:
If this command succeeds, it will display Success, followed by a JSON sequence describing the new state of the block device.
Not Found
For example:
Note that if you try to remove a tag from a block device that is not available, that is, to a block device that is in use, you will get a result like this:
Not Found
For example:
id tags
8 hello ssd trinkoplinko
For example:
id tags
9 20gig ssd
10 250Gs ssd
- Discover the ID of your partition
- Assign tags to a partition
- Remove tags from a partition
- List tags for all partitions
- View tags for one partition
|@tsv' | column -t
For example:
|@tsv' | column -t
system_id block_dev_id part_id path
xn8taa 8 67 /dev/disk/by-dname/sda-part1
The path component is printed to help you confirm that you are choosing the right partition, when there are several present.
For example:
If this command succeeds, it will display Success, followed by a JSON sequence describing the new state of the partition.
Not Found
For example:
Note that if you try to remove a tag from a partition that is not available, that is, to a partition that is in use, you will get a result like this:
Not Found
On the other hand, if you try to remove a tag that is not assigned to the partition you’ve chosen, MAAS will simply return Success, followed by a JSON sequence describing the current state of the partition.
| @tsv' | column -t
For example:
| @tsv' | column -t
id tags
54 farquar swap opendisk
67 foobar farquar
97 foobar
To view tags for one partition, enter a command similar to this:
For example:
This command should produce output similar to this:
id tags
67 foobar farquar
- Discover the ID of your network interface
- Assign tags to a network interface
- Remove tags from a network interface
- List tags for all network interfaces
- View tags for one network interface
|@tsv'| column -t
For example:
|@tsv'| column -t
mac_address type id tags
00:16:3e:18:7f:ee physical 9 andrpko plinko cochise
For example:
For example:
|@tsv'| column -t
For example:
|@tsv'| column -t
00:16:3e:18:7f:ee physical 9 andrpko plinko cochise farquar
|@tsv'| column -t
For example:
|@tsv'| column -t
- Identify your devices
- Assign tags to a device
- Remove tags from a device
- List tags for all devices
- View tags for one device
You can use a command similar to the following to identify your devices:
maas $PROFILE devices read \
|@tsv' | column -t
For example:
maas admin devices read \
|@tsv' | column -t
This command produces a result similar to the following:
hostname system_id
better-sole t8pmrs
light-aphid 76b6tt
To assign tags to a device, you can use a command of the following form:
For example:
maas admin tag update-nodes farquar add=t8pmrs
A successful command like this might produce output similar to this:
"added": 1,
"removed": 0
You can also check your work by listing tags for all devices.
To remove tags from a device, you can use a command of the following form:
For example:
maas admin tag update-nodes farquar remove=t8pmrs
"added": 0,
"removed": 1
If you want to list tags for all devices, you could use a command similar to this one:
| jq -r '(["hostname","system_id","tags"]
|@tsv' | column -t
For example:
|@tsv' | column -t
Such a command would produce output that looks something like this:
hostname system_id tags
better-sole t8pmrs farquar
light-aphid 76b6tt
You can view the tags for a single device with the command:
maas $PROFILE device read $SYSTEM_ID \
|@tsv' | column -t
If you need to know the system ID of your device, you can look it up.
Note that this command differs in that (1) it uses the singular “device” instead of “devices;” (2) it gives the system ID of a specific device; and (3) it uses the single-record form of the jq tag list ("([.hostname,.system_id,.tag_names[]]", rather than “(.[]|[.hostname…”).
For example:
maas admin device read t8pmrs \
|@tsv' | column -t
Sample output might look like this:
Work with node tags
- Identify your nodes
- Assign tags to a node
- Remove tags from a node
- List tags for all nodes
- View tags for one node
Identify your nodes
If you need to identify the system ID of your nodes, you can do so with a command like this one:
maas $PROFILE nodes read \
|@tsv'|column -t
For example:
When listing nodes, you should expect a large output, similar to this or larger:
hostname system_id
better-sole t8pmrs
light-aphid 76b6tt
divine-stork 8b3ypp
casual-prawn 4end6r
driven-teal tgaat6
good-osprey napfxk
smart-hen c4rwq7
boss-satyr xn8taa
crack-guinea qk4b3g
finer-leech cy3dtr
free-mouse gxtbq4
humble-bunny srqnnb
one-boa by477d
great-urchin srnx4g
ace-frog g6arwg
alive-marlin gbwnfb
tough-kit ke3wc7
legal-whale 8nq3mt
game-sponge 76pdc6
fun-ghoul qxfm7k
aware-earwig 8m8hs7
chief-crane 7fapx7
select-tapir 4ascbr
on-slug snfs8d
polite-llama dbqd4m
frank-coyote wcmk48
still-imp h6ra6d
A node listing will show all the machines, controllers, and devices in the system.
To assign tags to any node (regardless of its type), you can use a command of this form:
‘’‘bash
For example,
For example:
"added": 1,
"removed": 0
To remove tags from a node, regardless of type, you can use a command like this one:
For example:
"added": 0,
"removed": 1
If you want to list tags for all nodes, you could use a command similar to this one:
|@tsv' | column -t
For example:
maas admin nodes read \
|@tsv' | column -t
light-aphid 76b6tt
bill-Lenovo-Yoga-C740-15IML 86xya8 lxd-vm-host
You could use a command with a form like this to view the tags for one node:
maas $PROFILE node read $SYSTEM_ID \
|@tsv' | column -t
For example:
maas admin node read xn8taa \
|@tsv' | column -t
This command produces output that looks something like this:
Work with annotations
Work with static annotations
- Identify your machines
- Set a static annotation for a machine
- Change or clear a static annotation for a machine
- List static annotations for all machines
- View a static annotation for one machine
maas $PROFILE machines read \
|@tsv' | column -t
For example:
maas admin machines read \
|@tsv' | column -t
hostname system_id
divine-stork 8b3ypp
casual-prawn 4end6r
driven-teal tgaat6
good-osprey napfxk
smart-hen c4rwq7
boss-satyr xn8taa
crack-guinea qk4b3g
finer-leech cy3dtr
free-mouse gxtbq4
humble-bunny srqnnb
one-boa by477d
great-urchin srnx4g
ace-frog g6arwg
alive-marlin gbwnfb
tough-kit ke3wc7
legal-whale 8nq3mt
game-sponge 76pdc6
fun-ghoul qxfm7k
aware-earwig 8m8hs7
chief-crane 7fapx7
select-tapir 4ascbr
on-slug snfs8d
polite-llama dbqd4m
frank-coyote wcmk48
still-imp h6ra6d
For example:
|@tsv' | column -t
For example:
|@tsv' | column -t
hostname system_id description
driven-teal tgaat6 tango-golf
humble-bunny srqnnb sierra-romeo
tough-kit ke3wc7 kilo-echo
|@tsv' | column -t
For example:
|@tsv' | column -t
- Identify machines that can receive dynamic annotations
- Set dynamic annotations for a machine
- Clear and change dynamic annotations for a machine
- List dynamic annotations for all machines
- List dynamic allocations for one machine
|@tsv' | column -t
For example:
|@tsv' | column -t
hostname system_id status
divine-stork 8b3ypp Deployed
casual-prawn 4end6r Ready
driven-teal tgaat6 Allocated
immune-beetle 43xand Allocated
good-osprey napfxk Allocated
smart-hen c4rwq7 Allocated
boss-satyr xn8taa Ready
golden-martin 8fxery Allocated
crack-guinea qk4b3g Allocated
finer-leech cy3dtr Deployed
free-mouse gxtbq4 Allocated
humble-bunny srqnnb Allocated
wanted-muskox ekw7fh Deployed
one-boa by477d Allocated
great-urchin srnx4g Allocated
ace-frog g6arwg Ready
alive-marlin gbwnfb Deployed
picked-parrot am77wn Allocated
tough-kit ke3wc7 Deployed
legal-whale 8nq3mt Allocated
game-sponge 76pdc6 Allocated
fun-ghoul qxfm7k Allocated
aware-earwig 8m8hs7 Deployed
chief-crane 7fapx7 Ready
select-tapir 4ascbr Allocated
on-slug snfs8d Allocated
polite-llama dbqd4m Allocated
frank-coyote wcmk48 Allocated
usable-condor ed8hmy Deployed
still-imp h6ra6d Allocated
Dynamic annotations, otherwise known as “workload annotations” or “owner data,” can be used to keep track of the runtime status of machines that are acquired or deployed. These annotations are set using key=value pairs. You can set any key=value pair that you wish for any machine, although it’s probably more useful if you standardise your key names.
For example:
You can change dynamic annotations for a machine simply by executing a new set-owner-data command:
You can clear a dynamic annotation by entering the empty string ("") as the $VALUE:
|@tsv' | column -t
For example:
|@tsv' | column -t
hostname system_id owner_data
divine-stork 8b3ypp
casual-prawn 4end6r
driven-teal tgaat6 farquar foobar
good-osprey napfxk
smart-hen c4rwq7
|@tsv' | column -t
For example:
|@tsv' | column -t
