Questions you may have:
- What is MAAS?
- What does MAAS offer me?
- Can MAAS co-locate key components to conserve resources?
- How does MAAS work?
What is MAAS?
MAAS can act as a standalone PXE/preseed service or integrate with other technologies. It works exceptionally well with Juju
, the service and model management tool. MAAS manages the machines and Juju manages the services running on those machines – a perfect arrangement. Virtual machines (VMs) can even act as MAAS machines if they boot from the network via PXE.Tell me about PXE booting
What MAAS offers
[tabs]
[tab version="deb-3, snap-3, deb-3.1, snap-3.1, " view=“cli”]
MAAS also discovers all of the USB and PCI devices attached to your physical or virtual machines, and allows you to delete them from the machine’s visible configuration, prior to deployment, if you so desire.
[/tab]
[tab version="deb-3, snap-3, deb-3.1, snap-3.1, " view=“ui”]
[/tab]
[tab version="deb-2.9, deb-3, deb-3.1, snap-2.9, snap-3, snap-3.1, " view=“ui”]
- web UI (optimised for mobile devices)
- Ubuntu, CentOS, Windows, and RHEL installation support
- open-source IP address management (IPAM)
- full API/CLI support
- high availability (optional)
- IPv6 support
- inventory of components
- DHCP and DNS for other devices on the network
- DHCP relay integration
- VLAN and fabric support
- NTP for the entire infrastructure
- hardware testing
- composable hardware support
[/tab]
[tab version="deb-2.9, deb-3, deb-3.1, snap-2.9, snap-3, snap-3.1, " view=“cli”]
MAAS integrates all the tools you need into a smooth system-management experience. It includes the following eleven features:
- IPv6 support
- hardware testing
[/tab]
[/tabs]
MAAS works with any system configuration tools. Both the Chef
and Juju teams recommend MAAS as a physical provisioning system.Please note that Windows and RHEL images require Ubuntu Advantage
to work correctly with MAAS.Colocation of key components
How MAAS works
Commissioning means that MAAS has successfully booted the machine, scanned and recorded its resources, and prepared it for eventual deployment. Machines that you explicitly dd are automatically commissioned. MAAS marks a successfully-commissioned machine as “Ready” in the machine list.
[tabs]
[tab version="deb-2.9, snap-2.9, deb-3, snap-3, deb-3.1, snap-3.1, " view=“ui”]
[/tab]
[tab version="deb-2.9, snap-2.9, deb-3, snap-3, deb-3.1, snap-3.1, " view=“cli”]
[/tab]
[/tabs]
The above comment about disk space bears repeating: MAAS will overwrite the disk space of all machines it enlists. All pool machines are under the control of MAAS; you should provision them using other methods.
[tabs]
[/tab]
When acquiring machines from the API/CLI, you can specify requirements (“constraints”). Common constraints are memory, CPU cores, connected networks, and assigned physical zone.
[/tab]
[/tabs]
Note that Juju
is designed to work with MAAS. MAAS becomes a back-end Juju resource pool with all functionality fully available. For instance, if Juju removes a machine, then MAAS will release that machine to the pool. With Juju, MAAS can become an integral part of your data centre strategy and operations.
