I have tried many “different things” around boot-resources create thanks to the docs, the forums, google search, without succes.
And PS :
Unsupport operating system blablabla, supported operating systems: [‘ubuntu’, ‘ubuntu-core’, ‘bootloader’, ‘centos’, ‘rhel’, ‘custom’, ‘windows’, ‘suse’, ‘caringo’, ‘esxi’]
Can’t we have a kind of “raw”, like just write it?
You can upload custom images in dd format using a procedure similar to the one described in https://discourse.maas.io/t/using-static-ubuntu-images/5279 (see “How to upload a custom Ubuntu image”).
You need to specify the base_image field to match the operating system that image is based on.
But !
Your link is not working, searching discourse for the topic lead nowhere.
Also I repeat myself, it is not a custom ubuntu image.
It is not even a “custom” image of any OS at all.
Does MAAS can dd for me anything? Even garbage?
Thanks in advance,
Have a nice day,
Best Regards,
Mickaël.
I even didn’t noticed up to now, but I guess I crashed the rack controller which is now in a forever trying loop to handle the image.
Do you know how to clear the error ?
Doing :
maas $profile boot-resources create \
name='bootloader/garbage.1.2.3' \
title='Test Garbage Image 1.2.3' \
filetype='ddgz' \
content@=/tmp/test-garbage.1.2.3.img.gz
Apr 6 11:13:15 localhost sh[1249]: 2022-04-06 11:13:15 provisioningserver.rpc.common: [critical] Unhandled failure dispatching AMP command. This is probably a bug. Please ensure that this error is handled within application code or declared in the signature of the b'ListBootImages' command. [maas2:pid=1248:cmd=ListBootImages:ask=40]
Apr 6 11:13:37 localhost sh[1249]: #011builtins.ValueError: too many values to unpack (expected 3)
uname -a
Linux maas2 5.4.0-104-generic #118-Ubuntu SMP Wed Mar 2 19:02:41 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
lsb_release --all
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.4 LTS
Release: 20.04
Codename: focal
dpkg -l | grep maas
ii maas 1:3.1.0-10901-g.f1f8f1505-0ubuntu1~20.04.1 all "Metal as a Service" is a physical cloud and IPAM
ii maas-cli 1:3.1.0-10901-g.f1f8f1505-0ubuntu1~20.04.1 all MAAS client and command-line interface
ii maas-common 1:3.1.0-10901-g.f1f8f1505-0ubuntu1~20.04.1 all MAAS server common files
ii maas-dhcp 1:3.1.0-10901-g.f1f8f1505-0ubuntu1~20.04.1 all MAAS DHCP server
ii maas-proxy 1:3.1.0-10901-g.f1f8f1505-0ubuntu1~20.04.1 all MAAS Caching Proxy
ii maas-rack-controller 1:3.1.0-10901-g.f1f8f1505-0ubuntu1~20.04.1 all Rack Controller for MAAS
ii maas-region-api 1:3.1.0-10901-g.f1f8f1505-0ubuntu1~20.04.1 all Region controller API service for MAAS
ii maas-region-controller 1:3.1.0-10901-g.f1f8f1505-0ubuntu1~20.04.1 all Region Controller for MAAS
ii python3-django-maas 1:3.1.0-10901-g.f1f8f1505-0ubuntu1~20.04.1 all MAAS server Django web framework (Python 3)
ii python3-maas-client 1:3.1.0-10901-g.f1f8f1505-0ubuntu1~20.04.1 all MAAS python API client (Python 3)
ii python3-maas-provisioningserver 1:3.1.0-10901-g.f1f8f1505-0ubuntu1~20.04.1 all MAAS server provisioning libraries (Python 3)
apt list -a maas
Listing... Done
maas/focal,now 1:3.1.0-10901-g.f1f8f1505-0ubuntu1~20.04.1 all [installed]
maas/focal-updates 1:0.7 all
maas/focal 1:0.6 all
I’ve similar need, i.e. to dd some img (e.g. memtest86.img).
I’ve successfully uploaded the image by cheating base_image=ubuntu/focal, during the deployment it failed at curtin hook and status failed deployment in maas portal (see below for err msg). A quick check on the hdd found that it dd the image on the hdd (and bootable from efi shell). I guess I need to pack curtin/cloud-init or whatever into the img to make it work?
Running curtin builtin curthooks
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks: FAIL: curtin command curthooks
File "/curtin/curtin/commands/main.py", line 202, in main
ret = args.func(args)
File "/curtin/curtin/commands/curthooks.py", line 1886, in curthooks
builtin_curthooks(cfg, target, state)
File "/curtin/curtin/commands/curthooks.py", line 1681, in builtin_curthooks
distro_info = distro.get_distroinfo(target=target)
File "/curtin/curtin/distro.py", line 118, in get_distroinfo
variant_name = variant_os_release['ID']
KeyError: 'ID'
'ID'
curtin: Installation failed with exception: Unexpected error while running command.
Command: ['curtin', 'curthooks']
Exit code: 3
MAAS doesn’t support deploying arbitrary images, it needs some preconditions and assumptions to be fulfilled. You can try to trick MAAS into deploying your image by:
using a raw image (dd.gz)
creating the boot-resource with base_image set to something MAAS knows how to deploy (e.g. ubuntu/focal)
inhibiting the default Curtin hook by adding a /curtin/curtin-hooks script to the image.
adding cloud-init to the system initialization, or a script that downloads cloud-init’s user-data from MAAS during the first boot.
adding a dpkg-query script to fake the presence of packages (when the system is not ubuntu based)
DISCLAIMER: this is NOT supported. These tricks might get you far, but there’s no guarantee it will work in end.
