About customising machines
MAAS provides the capability to customise machines.
How to customise machine storage
This section will show you:
Note that layouts can be set globally and on a per-machine basis. For additional information on storage layouts, see the Storage layouts reference article.
[tabs]
[tab version=“v3.4 Snap,v3.4 Packages,v3.3 Snap,v3.3 Packages,v3.2 Snap,v3.2 Packages,v3.1 Snap,v3.1 Packages,v3.0 Snap,v3.0 Packages,v2.9 Snap,v2.9 Packages” view=“UI”]
[/tab]
[tab version=“v3.4 Snap,v3.4 Packages,v3.3 Snap,v3.3 Packages,v3.2 Snap,v3.2 Packages,v3.1 Snap,v3.1 Packages,v3.0 Snap,v3.0 Packages,v2.9 Snap,v2.9 Packages” view=“CLI”]
[/tab]
[/tabs]
[tabs]
[/tab]
[/tab]
[/tabs]
[tabs]
  1. Click on Settings" → Storage.
  2. Set or clear Erase machines’ disks prior to releasing. If you set this option, users will be compelled to use disk erasure: that option will be pre-filled in the machine’s view and the user will be unable to remove the option.
[/tab]
How to erase disks
and not:
How to list block devices
Output:
        "id": 10,
        "serial": ",
        "block_size": 4096,
        "available_size": 0,
        "filesystem": null,
        "id_path": "/dev/vda",
        "size": 5368709120,
        "model": ",
        "type": "physical",
        "uuid": null,
        "used_size": 5365563392,
        "partitions": [
                "bootable": false,
                "id": 9,
                "size": 5360320512,
                "type": "partition",
                "filesystem": {
                    "mount_options": null,
                    "label": null,
                    "fstype": "lvm-pv",
                    "mount_point": null
        "tags": [
            "rotary"
        "name": "vda"
        "id": 11,
        "serial": null,
        "block_size": 4096,
        "filesystem": {
            "label": "root",
            "fstype": "ext4",
            "mount_point": "/"
        "id_path": null,
        "size": 3221225472,
        "partition_table_type": null,
        "model": null,
        "type": "virtual",
        "used_size": 3221225472,
        "partitions": [],
        "tags": [],
        "name": "vgroot-lvroot"
How to read a block device
    "name": "vgroot-lvroot",
    "type": "virtual",
    "filesystem": {
        "mount_point": "/",
        "fstype": "ext4",
        "label": "root"
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
How to create a block device
    "name": "vdb",
    "used_for": "Unused",
    "type": "physical",
    "used_size": 0,
    "filesystem": null,
    "id_path": ",
    "id": 12,
    "block_size": 4096,
    "tags": [],
    "uuid": null,
    "serial": "QM00001",
    "partitions": [],
    "size": 21474836480,
    "model": "QEMU"
How to update a block device
    "block_size": 4096,
    "filesystem": null,
    "model": "QEMU",
    "name": "newroot",
    "partitions": [],
    "tags": [],
    "used_size": 0,
    "id_path": ",
    "uuid": null,
    "id": 12,
    "type": "physical",
    "serial": "QM00001"
How to delete a block device
How to format a block device
    "block_size": 4096,
    "size": 3221225472,
    "filesystem": {
        "label": ",
        "fstype": "ext4",
        "mount_point": null
    "model": null,
    "partitions": [],
    "tags": [],
    "id_path": null,
    "id": 11,
    "type": "virtual",
    "serial": null
    "available_size": 3221225472,
    "type": "virtual",
    "used_size": 0,
    "filesystem": null,
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
How to mount a block device
    "type": "virtual",
    "filesystem": {
        "mount_point": "/srv",
        "mount_options": ",
        "fstype": "ext4",
        "label": "
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
How to unmount a block device
    "type": "virtual",
    "filesystem": {
        "mount_point": null,
        "fstype": "ext4",
        "label": "
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
Only an administrator can set which block device should be used as the boot disk and only a physical block device can be set as as the boot disk. This operation should be done before a machine is allocated or the storage layout will be applied to the previous boot disk.
How to list partitions
        "bootable": false,
        "id": 9,
        "resource_uri":
        "size": 5360320512,
        "filesystem": {
            "label": null,
            "fstype": "lvm-pv",
            "mount_point": null
How to create a partition
    "bootable": false,
    "filesystem": null,
    "id": 10,
    "size": 5360320512,
How to delete a partition
How to format a partition
    "id": 9,
    "size": 5360320512,
    "bootable": false,
    "filesystem": {
        "fstype": "ext4",
        "label": "
How to unformat a partition
    "bootable": false,
    "filesystem": null,
    "id": 10,
    "size": 5360320512,
How to mount a partition
    "bootable": false,
    "id": 10,
    "size": 5360320512,
    "filesystem": {
        "mount_options": ",
        "label": ",
        "fstype": "ext4",
How to unmount a partition
    "bootable": false,
    "id": 10,
    "size": 5360320512,
    "filesystem": {
        "label": ",
        "fstype": "ext4",
        "mount_point": null
    "id": 3,
    "size": 2000003072
How to list VMFS datastores
        "human_size": "45.8 GB",
        "filesystem": {
            "fstype": "vmfs6",
        "name": "datastore1",
        "system_id": "4qxaga",
        "devices": [
                "size": 35026632704,
                "bootable": false,
                "tags": [],
                "filesystem": {
                    "fstype": "vmfs6",
                    "label": null,
                "device_id": 5,
                "id": 71,
                "size": 10729029632,
                "bootable": false,
                "tags": [],
                "filesystem": {
                    "fstype": "vmfs6",
                    "label": null,
                "device_id": 6,
                "id": 77,
        "id": 17,
        "size": 45755662336,
How to view a VMFS datastore
    "system_id": "b66fn6",
    "id": 18,
    "filesystem": {
        "fstype": "vmfs6",
    "human_size": "2.8 GB",
    "devices": [
            "size": 2814377984,
            "bootable": false,
            "tags": [],
            "id": 80,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "device_id": 1,
    "size": 2814377984,
    "devices": [
            "size": 2814377984,
            "bootable": false,
            "tags": [],
            "device_id": 1,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "id": 80,
    "name": "datastore42",
    "filesystem": {
        "fstype": "vmfs6",
    "id": 19,
    "size": 2814377984,
How to edit a VMFS datastore
    "id": 19,
    "filesystem": {
        "fstype": "vmfs6",
    "human_size": "13.5 GB",
    "devices": [
            "size": 2814377984,
            "bootable": false,
            "tags": [],
            "id": 80,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "device_id": 1,
            "bootable": false,
            "tags": [],
            "id": 86,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "device_id": 2,
    "size": 13543407616,
[/tab]
[/tabs]
How to pre-seed with curtin
You can customise the Curtin installation by either editing the existing curtin_userdata template or by adding a custom file as described above. For a flowchart, showing where Curtin and pre-seeding fits into the deployment picture, see How images get deployed.
Curtin provides hooks to execute custom code before and after installation takes place. These hooks are named early and late respectively, and they can both be overridden to execute the Curtin configuration in the ephemeral environment. Additionally, the late hook can be used to execute a configuration for a machine being installed, a state known as in-target.
This syntax won’t work because the value of sh’s -c argument is itself an entire command. The correct way to express this is:
early_commands:
late_commands:
How to pre-seed with cloud-init
For a flowchart, showing where cloud-init fits into the deployment picture, see How images get deployed.
[tabs]
[tab version=“v3.4 Snap,v3.4 Packages” view=“UI”]
To customise cloud-init via the web UI:
  1. Select Machines.
  2. Select a machine.
  3. Select Actions > Deploy.
  4. Checkbox Cloud-init user-data….
  5. Paste, upload, or drag-and-drop the script into the box.
  6. Select Start deployment for machine.
    [/tab]
    [tab version=“v3.3 Snap,v3.3 Packages,v3.2 Snap,v3.2 Packages,v3.1 Snap,v3.1 Packages,v3.0 Snap,v3.0 Packages,v2.9 Snap,v2.9 Packages” view=“UI”]
  7. Select a machine.
  8. Choose Take action >> Deploy.
  9. Select a viable release.
  10. Check the box labelled Cloud-init user-data….
  11. Paste the desired script directly into the box.
  12. Select Start deployment for machine.
For example, to import an SSH key immediately after your machine deployment, you could paste this script:
#!/bin/bash
echo === $date ===
ssh-import-id foobar_user
) | tee /ssh-key-import.log
No script validation of any kind is provided with this capability. You will need to test and debug your own cloud-init scripts.
[/tab]
Using cloud-init to customise a machine after deployment is relatively easy. After you’re logged in, use the following command to deploy a machine with a custom script you’ve written:
The three replaceable parameters shown above decode to:
  1. $PROFILE: Your MAAS login. E.g. admin
  2. $SYSTEM_ID: The machine’s system ID (see example below)
  3. <base-64-encoded-script>: A base-64 encoded copy of your customisation script. See below for an example.
E.g.:
Suppose you would like to import an SSH key immediately after your machine deployment. First, you want to find the machine’s system_id, which you can do with this short, command-line jq script:
maas admin machines read | jq -r '(["HOSTNAME","SYSID"] | (., map(length*"-"))),
You might then use this script, called import_key.sh, to retrieve the needed key:
#!/bin/bash
echo === $date ===
This script echoes the date in addition to the output of the ssh-import-key command. It also adds that output to a file, /ssh-key-import.log.
Base-64 encoding is required because the MAAS command-line interacts with the MAAS API, and base-64 encoding allows MAAS to send the script inside a POST HTTP command.
Use the base64 command to output a base-64 encoded version of your script:
base64 -w0 ./import_key.sh
Putting it together:
maas $PROFILE machine deploy $SYSTEM_ID user_data=$(base64 -w0 ./import_key.sh)
After MAAS deploys the machine, you’ll find /ssh-key-import.log on the machine you deployed.
[/tab]
[/tabs]
How to choose Ubuntu kernels
[tabs]
To set the default minimum enlistment and commissioning kernel for all machines:
  1. Select Settings.
  2. Select Configuration.
  3. Select Commissioning.
  4. Select a kernel from the Default minimum kernel version drop-down.
  5. Select Save to register your changes.
    [/tab]
    To set the default minimum enlistment and commissioning kernel (based on Ubuntu release: GA kernel) for all machines:
  6. Select Settings >> General.
  7. Select a kernel in the Default Minimum Kernel Version field of the Commissioning section
To set the minimum deploy kernel on a machine basis:
  1. Select Machines.
  2. Click on a machine.
  3. Select Configuration.
  4. Select Edit in the Machine configuration section.
  5. Select a kernel in the Minimum Kernel field.
To set a specific kernel during deployment:
  1. Select Machines.
  3. Choose Take action >> Deploy.
  4. Choose a kernel from the third kernel field.
  5. Click Deploy machine to initiate the deployment.
MAAS verifies that the specified kernel is available for the given Ubuntu release (series) before deploying the machine.
[/tab]
[/tab]
[/tabs]
How to set global kernel boot options
[tabs]
To set global kernel boot options:
  1. Select Settings.
  2. Select Configuration > Kernel parameters.
  3. Enter the Global boot parameters always passed to the kernel in the text box.
  4. Select Save to register your changes.
    [/tab]
    To set kernel boot options globally:
  5. Make sure that you are logged in as an administrator.
  6. Go to Settings >> General.
  7. Scroll down to the Global Kernel Parameters section:
  8. Type in the desired (space separated) options.
  9. Be sure to click Save.
The contents of the field will be used as-is. Do not use extra characters.
[/tab]
You can set kernel boot options and apply them to all machines with the CLI command:
maas $PROFILE maas set-config name=kernel_opts value='$KERNEL_OPTIONS'
[/tab]
[/tabs]
How to create tags with built-in kernel options
For example:
    "name": "nomodeset_tag",
    "definition": ",
| @tsv' | column -t
virtual
How to use resource pools
[tabs]
[tab version=“v3.3 Snap,v3.3 Packages” view=“UI”]
How to add a resource pool
To add a resource pool:
  1. Select Organisation > Pools.
  2. Select Add pool.
  3. Give your new pool a name.
  4. Optionally, give your new pool a description.
  5. Select Save pool to register the changes.
How to delete a resource pool
To delete a resource pool:
  2. Select the trash can icon to the far right of the pool row.
  3. Select Delete.
The pool will be deleted; there is no confirmation dialogue.
When you delete a resource pool, no machines will be deleted: All machines that belong to that resource pool will return to the default pool.
How to add a machine to a resource pool
To add a machine to a resource pool:
  1. Select Machines.
  2. Checkbox the machine(s) you want to add to the resource pool.
  3. Select Categorise > Set pool….
  4. Choose Select pool.
  5. Select the desired resource pool from the Resource pool drop-down.
  6. Alternatively, you can choose Create pool and create a new pool to add to the machine(s).
  7. Register your changes by clicking Set pool….
How to remove a machine from a resource pool
To remove a machine from a resource pool, follow the procedure for adding a machine to a resource pool, but select “default” as the new resource pool. This action will return the machine to the default resource pool.
How to add a VM host to a resource pool
You can add a VM host to a resource pool when you create a new VM host or you can edit a VM host’s configuration:
  1. Select KVM > LXD.
  2. Select the KVM you want to add to a resource pool.
  3. Select KVM host settings.
  4. Select the desired pool in the Resource pool drop-down.
  5. Register your changes with Save changes.
How to remove a VM host from a resource pool
To remove a VM host from a resource pool, follow the same procedure you would use to add a VM host to a resource pool, selecting “default” as the new resource pool. This action will return the machine to the default resource pool.
[/tab]
  1. From the machine list, click the top tab Resource pool.
  2. Select Add pool.
  3. Select Delete.
  1. Select Machines.
  2. Select the machine you want to add to the resource pool.
  4. Select Edit in the Machine configuration block.
  6. Register your changes by clicking Save changes.
  1. Select KVM from the top tab bar.
[/tab]
How to create a resource pool
How to list available resource pools
How to list a single resource pool
How to update a resource pool
[/tab]
[/tabs]
About customising deployed machines
[tabs]
How to enable hardware sync on a machine
MAAS hardware sync may leak the MAAS admin API token. You may need to rotate all admin tokens and re-deploy all machines that have hardware sync enabled. To find out whether this is an issue, and how to fix it, see the troubleshooting instructions for this problem.
To enable Hardware sync on a machine:
  1. Select Machines.
  2. Select a machine(s).
  3. Select Actions > Deploy*.
  4. Check Periodically synch hardware.
  5. Select Start deployment….
Once you’ve enabled hardware sync, any changes you make to the physical device, or to the VM through the VM host, will show up in the appropriate page for the deployed machine as soon as the sync interval has passed.
How to view updates from hardware sync
To view updates from hardware sync:
  1. Select Machines.
  2. Select the machine in question.
Any changes to the machine’s hardware configuration will be updated on the next sync. The status bar at the bottom will show times for Last synced and Next sync. Updated BMC configuration and tags can also be viewed on the machine itself.
How to configure hardware sync interval
The hardware sync interval is configured globally in MAAS deployment settings.
[/tab]
[tab version=“v3.3 Snap,v3.3 Packages,v3.2 Snap,v3.2 Packages” view=“UI”]
  1. Select Machines.
  3. Select Take action >> Deploy*.
  5. Select Start deployment for machine.
  1. Select Machines.
[/tab]
[tab version=“v3.4 Snap,v3.4 Packages,v3.3 Snap,v3.3 Packages,v3.2 Snap,v3.2 Packages” view=“CLI”]
To enable Hardware sync on a machine, deploy the machine from the command line, adding enable_hw_sync=true:
maas $PROFILE machine deploy $SYSTEM_ID osystem=$OSYSTEM distro_series=$VERSION enable_hw_sync=true
Hardware sync updates the machine’s blockdevice, interface and device sets on a periodic basis. These can be viewed with the CLI command:
The timestamps of the last time data was synced and the estimated next time the machine will be synced can be seen in the last_sync and next_sync fields respectively.
[/tab]
[tab version=“v3.1 Snap,v3.1 Packages,v3.0 Snap,v3.0 Packages,v2.9 Snap,v2.9 Packages” view=“UI,CLI”]
Note that MAAS version 3.2 introduces the capability to sync and update hardware configuration on deployed, running machines.
[/tab]
[/tabs]
