Commissioning scripts are small programs that MAAS runs when a machine is first commissioned. They detect hardware, configure settings, and prepare machines for deployment. MAAS comes with a number of built-in scripts, but you can also create your own to extend or customise commissioning.
Why commissioning scripts matter
When MAAS commissions a machine, it needs reliable data about:
- CPU, memory, and NUMA layout.
- Network interfaces and firmware.
- Vendor- or model-specific quirks (e.g. enabling embedded controllers).
Commissioning scripts gather this information and can also run hardware-specific configuration tasks. Well-written scripts ensure that MAAS knows exactly what resources are available and that machines are ready to deploy workloads.
Standard commissioning scripts
MAAS provides a set of standard commissioning scripts out of the box. These scripts:
- Detect CPU, memory, and NUMA layout.
- Collect storage and PCI/USB device data.
- Run smartctl checks on disks.
- Validate network devices and links.
- Apply firmware updates or controller settings on specific hardware.
Each built-in script has a name and a title (friendly name shown in the UI). You can inspect these in the MAAS interface under Settings → Scripts or via the CLI.
Script structure
A commissioning script is just a shell, Python, or similar program with a metadata header. The metadata tells MAAS when and how to run the script. For example:
title: Storage health check
description: Verify that the selected storage device is present and writable
type: commissioning
timeout: 00:10:00
tags: [storage]
hardware_type: storage
After the metadata, you write the executable code. MAAS handles execution, logging, and result collection.
Naming conventions
Scripts are sorted alphabetically by name. To control execution order:
- Built-in scripts typically use prefixes like
00-,10-,20-. - Custom scripts should start later in the order (e.g.
50-or higher) so they run after the built-ins.
For example:
00-maas-01-power-info(built-in).50-my-storage-check(custom).
Key metadata fields
The metadata block supports several important fields:
- type:
commissioningortesting. Determines when the script runs. - timeout: Time limit (seconds or HH:MM:SS).
- destructive: Whether the script alters system data (can’t run on deployed machines).
- parallel: Whether scripts can run concurrently (
disabled,instance,any). - may_reboot: If true, MAAS tolerates up to 20 minutes of downtime during reboots.
- tags: Labels for searching and filtering scripts.
- hardware_type / for_hardware: Restrict execution to specific hardware classes or devices.
Parameters and results
Scripts can take parameters and must produce results in YAML. For example:
Python example with argparse:
#!/usr/bin/env python3
# Metadata block here
import argparse
parser = argparse.ArgumentParser()
parser.add_argument('--storage', required=True)
args = parser.parse_args()
print(f"Testing: {args.storage}")
Bash example:
#!/bin/bash
echo "Model: $1"
echo "Serial: $2"
Environment variables
MAAS sets a number of environment variables to help your script:
OUTPUT_STDOUT_PATH– log path for standard output.OUTPUT_STDERR_PATH– log path for error output.RESULT_PATH– location for writing result YAML.
Use these to return structured results and logs that MAAS can display in the UI.
Example: vendor-specific configuration
Here’s a real-world example of configuring an Intel C610/X99 HPA controller on HP systems:
#!/bin/bash -ex
output=$(sudo hprest get EmbeddedSata --selector HpBios)
echo "$output" > $RESULT_PATH
This script interacts with vendor tools to configure hardware during commissioning.
Best practices
- Keep scripts simple and focused. One task per script.
- Fail fast. Return clear error messages if requirements aren’t met.
- Avoid destructive operations unless absolutely necessary (and mark them as such).
- Name scripts carefully. Use prefixes (
50-,60-) to control order. - Test iteratively. Run your script manually in a commissioning environment before uploading.
Key takeaway
Commissioning scripts are the extensibility point of MAAS: they let you adapt commissioning to your hardware and environment. By understanding script metadata, naming rules, and built-in behaviours, you can write your own scripts to make MAAS commissioning as thorough and reliable as your fleet demands.
