3.6.0 Release Schedule
Below is our plan for releasing MAAS 3.6.0.
Beta and RC versions might be adjusted depending on the ongoing work progress and the tests results.
Version Date Status
3.6.0-beta1 20 Dec 2024 released
3.6.0-RC1 25 Feb 2025 released
3.6.0-RC2 - internal use only
3.6.0-RC3 - internal use only
3.6.0-RC4 - internal use only
3.6.0-RC5 31 Mar 2025 released
3.6.0-Final 16 Apr 2025 released
16 Apr 2025
3.6.0 is available in snap 3.6/stable channel or in deb via ppa:maas/3.6.
After some focused debugging work, version 3.6.0 is now available.
31 Mar 2025
3.6.0 RC-5 has been released.
A few internal releases have been developed over the past few weeks. After some evaluations, the team has decided that RC5 includes the expected improvements over RC1 and is now available.
As always, your feedback is welcome.
25 Feb 2025
3.6.0 RC-1 is now available. You can install it via snap on the 3.6/candidate channel or through deb via the ppa:maas/3.6-next repository.
Over the next two weeks, we welcome any feedback or bug reports you might have.
08 Jan 2025
Next release is expected to be 3.6.0-RC1 and it should happen in the second half of the month.
The team is currently addressing a few bugs and working on simplifying some legacy code.
20 Dec 2024
3.6.0 beta1 is available in snap 3.6/beta channel.
As the first 3.6 beta release, you might experience some unexpected behavior in MAAS. If that is the case, first visit this page with the issues that have been identified and are currently being addressed for the MAAS 3.6 release. In the case that you find anything that has not been registered yet, report it using this link. Someone in the team will review it.
Hey folks, just curious… When the Debian packages will be available for testing?
I can’t find 3.6.0-beta1 in here:
Cheers!
Hi @Tiagonix
Oh, thats unfortunate.
We will check why the package was not copied under ppa:maas/3.6-next
Meanwhile you can try out the package that @javier-fs has built MAAS 3.6 builds : Javier Fuentes
Hi @Tiagonix,
the Debian packages for 3.6.0-beta1 are already available :slight_smile:
When do you expected 3.6.0 to be rolled out to the stable branch ?
rc1 is out right now. We expect rc2 around end of next week and then final around the week after.
Does this have bluefield3 support?
No, support for BF3 will begin with version 3.7
When is the expected date for 3.7.0?
We don’t have a decision yet but given that we want to align with the Ubuntu releases we can expect 3.7 in October more or less.
