I have already setup MAAS on one host. I am trying to deploy to another host, ubuntu 18.04 LTS with KVM host support, but it always ends with “Failed deployment”.
Event log had two errors:
Mon, 23 Sep. 2019 09:52:26 - Marking node failed - Internal error while creating KVM pod. (See regiond.log for details.)
Mon, 23 Sep. 2019 09:31:34 - Script result lookup or storage error - driven-cod.maas(kf6ybr): commissioning script '99-maas-03-network-interfaces' failed during post-processin
My controller regiond.log had this error:
2019-09-23 09:52:26 metadataserver.api_twisted: [critical] Exception while saving pod form.
File "/usr/lib/python3/dist-packages/maasserver/utils/orm.py", line 756, in call_within_transaction
File "/usr/lib/python3/dist-packages/maasserver/utils/orm.py", line 563, in retrier
return func(*args, **kwargs)
File "/usr/lib/python3.6/contextlib.py", line 52, in inner
return func(*args, **kwds)
File "/usr/lib/python3/dist-packages/metadataserver/api_twisted.py", line 390, in _processMessage
_create_pod_for_deployment(node)
File "/usr/lib/python3/dist-packages/metadataserver/api_twisted.py", line 213, in _create_pod_for_deployment
pod_form.save()
File "/usr/lib/python3/dist-packages/maasserver/forms/pods.py", line 282, in save
return self.discover_and_sync_pod()
File "/usr/lib/python3/dist-packages/maasserver/forms/pods.py", line 359, in discover_and_sync_pod
raise PodProblem(str(error))
maasserver.exceptions.PodProblem: Failed talking to pod: Failed to login to virsh console.
I can SSH into the machine which the deploy failed. KVM is installed, and there is a user named virsh. I don’t know the password as it is setup by MAAS. I checked the /etc/shadow file and theres a password there. I can’t register it in PODS cause i dont know the unencrypted pass.
However, why is virsh failing to login to console?
The host machine interface setup has the following details:
- br-eno1, bridge, DHCP externally assigned with internet access, no vlan tag
- br-eno2.100, bridge, MAAS managed DHCP, vlan tag 100
