Hey guys,
When I install MaaS 2.5 in the AIO (All-In-One) mode, everything works (almost) fine, like:
apt install maas
maas init
# enable dhcp
# PXE boot good to go and Machine deployment works (both physical and under Pods).
So far, so good!
However, when try ti isolate the Rack Controller in a different server, the IPMI appears as “Unknown”, after enlisting it, like:
# Server A
apt install maas-region-controller
... all good
# Server B
apt install maas-rack-controller
# register Rack against Region (it works, since I can see it under Controllers)
Thing is, here, after first PXE boot, after enlisting a Machine, it’s IMPI is not configured correctly.
If I return the “maas-rack-controller” to “Server A”, everything works again!
Here is the network config:
When it works? AIO:
Server A:
- 192.168.4.5/22 - eth0 - untagged maas pxe boot
- 192.168.0.5/22 - eth0.2 - tagged VLAN for mgmt
All good!
Trying to isolate Rack Controller… Not so good:
Server A (Region):
Server B (Rack):
- 192.168.4.6/22 - eth0 - untagged maas pxe boot
- 192.168.0.6/22 - eth0.2 - tagged VLAN for mgmt
Then, IPMI doesn’t work…
NOTE: When isolating, Server A doesn’t have any connectivity with the PXE subnet, which also (PXE subnet) doesn’t have a gateway.
Any idea?!
Cheers!
Thiago
