Hi.
I was trying to deploying a CentOS 6 image and I am having a curtin error below
Stdout: start: cmd-install/stage-curthooks/builtin/cmd-curthooks: curtin command curthooks
running /tmp/tmp_zvit2yw/target/curtin/curtin-hooks
Running command ['/tmp/tmp_zvit2yw/target/curtin/curtin-hooks'] with allowed return codes [0] (capture=False)
File "/tmp/tmp_zvit2yw/target/curtin/curtin-hooks.py", line 393, in <module>
main()
File "/tmp/tmp_zvit2yw/target/curtin/curtin-hooks.py", line 376, in main
grub_root = get_grub_root(target)
File "/tmp/tmp_zvit2yw/target/curtin/curtin-hooks.py", line 208, in get_grub_root
return regex.groups()[0]
AttributeError: 'NoneType' object has no attribute 'groups'
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks: FAIL: curtin command curthooks
File "/curtin/curtin/commands/main.py", line 201, in main
ret = args.func(args)
File "/curtin/curtin/commands/curthooks.py", line 1287, in curthooks
if util.run_hook_if_exists(target, 'curtin-hooks'):
File "/curtin/curtin/util.py", line 883, in run_hook_if_exists
subp([target_hook])
File "/curtin/curtin/util.py", line 275, in subp
return _subp(*args, **kwargs)
File "/curtin/curtin/util.py", line 141, in _subp
cmd=args)
Command: ['/tmp/tmp_zvit2yw/target/curtin/curtin-hooks']
Exit code: 1
Reason: -
Stdout: ''
Stderr: ''
Exit code: 1
Reason: -
Stdout: ''
Stderr: ''
Stderr: ''
The CentOS 6 is directly from the MaaS image repository with no customisation.
Thanks.
Regards,
De Lin
