To upgrade MAAS from 2.9 to 3.0:
Back up your MAAS server completely; the tools and media are left entirely to your discretion. Just be sure that you can definitely restore your previous configuration, should this procedure fail to work correctly.
Add the MAAS 3.0 PPA to your repository list with the following command, ignoring any apparent error messages:
sudo apt-add-repository ppa:maas/3.0
- Run the MAAS upgrade like this:
sudo apt update
sudo apt upgrade maas
Check your running MAAS install (by looking at the information on the bottom of the machine list) to make sure you’re running the 3.0 release.
If this didn’t work, you will need to restore from the backup you made in step 1, and consider obtaining separate hardware to install MAAS 3.0.
How to upgrade from 2.8 or lower to MAAS 3.0
If you are running MAAS 2.8 or lower, you must also make sure that the target system is running Ubuntu 20.04 LTS or higher, by executing the following command:
lsb_release -a
Distributor ID: Ubuntu
Description: Ubuntu xx.yy
Release: xx.yy
Codename: $RELEASE_NAME
The minimum “xx.yy” required for MAAS 3.0 is “20.04,” code-named “focal.”
If you are currently running Ubuntu bionic 18.04 LTS, you can upgrade to focal 20.04 LTS with the following procedure:
- Upgrade the release:
Accept the defaults for any questions asked by the upgrade script.
Reboot the machine when requested.
Check whether the upgrade was successful:
lsb_release -a
Description: Ubuntu 20.04(.nn) LTS
Release: 20.04
Codename: focal
If you’re upgrading from MAAS version 2.8 or lower to version 3.0: While the following procedures should work, note that they are untested. Use at your own risk. Start by making a verifiable backup; see step 1, below.
- Run the release upgrade like this, answering any questions with the given default values:
- Check whether your upgrade has been successful by entering:
lsb_release -a
No LSB modules are available.
Release: 20.04
Codename: focal
