How to use LXD (snap/2.9/CLI)
Reading package lists... Done
Building dependency tree
After this operation, 34.1 MB disk space will be freed.
$ sudo apt-get autoremove -y
$ sudo snap install lxd
R\How to refresh LXD on 20.04
$ sudo snap refresh
All snaps up to date.
$ sudo lxd init
  1. Would you like to use LXD clustering? (yes/no) [default=no]: no - MAAS does not currently support LXD clusters.
  2. Name of the storage back-end to use (btrfs, dir, lvm, zfs, ceph) [default=zfs]: dir - testing has primarily been with dir; other options should work, but less testing has been done, so use at your own risk.
  3. Would you like to connect to a MAAS server? (yes/no) [default=no]: no - When LXD is connected to MAAS containers or virtual machines created by LXD will be automatically added to MAAS as devices. This feature should work, but has limited testing thus far.
Address to bind LXD to (not including port) [default=all]:
Again:
lxc network show lxdbr0
config:
  dns.mode: managed
  ipv4.address: 10.146.214.1/24
  ipv4.dhcp: "true"
  ipv4.nat: "true"
  ipv6.dhcp: "true"
  ipv6.nat: "true"
description: ""
type: bridge
used_by:
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
$ lxc network show lxdbr0
config:
  dns.mode: none
  ipv4.dhcp: "false"
  ipv4.nat: "true"
  ipv6.dhcp: "false"
  ipv6.nat: "true"
description: ""
type: bridge
used_by:
managed: true
status: Created
locations:
- none
