About zones (deb/3.0/CLI)
2.9 3.0
DEB CLI ~ UI CLI ~ UI
SNAP CLI ~ UI CLI ~ UI
This page provides several useful examples of MAAS zone usage.
Fault tolerance
Service performance
Power management
