How to improve the doc (snap/2.9/UI)
Contribution overview
Style and language
  • Use a spell checker.
  • Resist being overly formal.
Headers
... and so on...
Bold and Italic Text
<strong>Bold Text</strong>
<em>Italic Text</em>
**strong**
Code blocks
maas command do something
  • a command line sequence,
Inline code
Admonishments
Admonishment text.
[/note]
Where:
Admonishment examples
Note Admonishment
[note status="Note"]
key.
[/note]
And it will appear as:
Warning Admonishment
[/note]
And it will appear like this:
Positive Admonishment
[/note]
Negative Admonishment
[/note]
Comments
[visible text](URL)
Images
<a href="https://discourse-maas-io-uploads.s3.us-east-1.amazonaws.com/original/1X/1f2e6cf2879e391e7ae1ad537cc9ce1baa119f86.png" target = "_blank"><img src="https://discourse-maas-io-uploads.s3.us-east-1.amazonaws.com/original/1X/1f2e6cf2879e391e7ae1ad537cc9ce1baa119f86.png"></a>
Tiered sections
<details>
<details>
</details>
</details>
Capitalisation
