Contribution overview
Once you have permission to edit the doc, you can modify any article by choosing the link at the bottom, entitled, “Help improve this document in the forum.” Recognize that what you change will be posted instantly. Check your work carefully before saving your edits!
Does your reply improve the conversation in some way?
Is your contribution kind to fellow community members?
Is your constructive criticism focused on ideas, and not people?
Are you certain of the technical accuracy of your contribution?
Style and language
- Use a spell checker.
- Resist being overly formal.
- Verify hyperlinks and examples.
- Target audience: intermediate system administrator, not a developer.
- Use British English (en-GB). See language details, including a comparison with American English (en-US).
- Never break a hyperlink with a carriage return.
Headers
... and so on...
Bold and Italic Text
<strong>Bold Text</strong>
<em>Italic Text</em>
**strong**
Code blocks
maas command do something
- a command line sequence,
- a pre-formatted block of text,
- a block of text in which you need to escape markup sequences (as above),
- a code listing where indentation and monospace font are important.
Inline code
Use a <code> tag to mark inline filenames and other literals
as code examples. Alternatively, you can also use the backtick
, like this:
Admonishments
An admonishment distinguishes information from the rest of the text. The syntax begins with the markup tag [note]
and ends with the corresponding closure [/note]
Admonishment text.
[/note]
Where:
admonishment-type
can be ‘Note’, ‘Warning’, ‘Positive’, or ‘Negative’. -
Admonishment title
is an optional title, formatted with whatever markups you desire. -
Admonishment text
is the text you wish to convey.
Admonishment examples
Note Admonishment
[note status="Note"]
key.
[/note]
And it will appear as:
Warning Admonishment
[/note]
And it will appear like this:
Positive Admonishment
[/note]
Negative Admonishment
[/note]
Comments
Occasionally it may be appropriate to include a comment to explain or organize some text. This ends up as an HTML comment – which can be read online, even if only in the browser inspection window – so take it seriously:
Hyperlinks
[visible text](URL)
The visible text
is what will appear on the web page. The URL
is used to refer to the destination, which is a fully-qualified URL. For example:
Images
An image should not be overly cropped - allow for context. When ready, place the image file in the uploads
directory.
<a href="https://discourse.maas.io/uploads/default/original/1X/1f2e6cf2879e391e7ae1ad537cc9ce1baa119f86.png" target = "_blank"><img src="https://discourse.maas.io/uploads/default/original/1X/1f2e6cf2879e391e7ae1ad537cc9ce1baa119f86.png"></a>
Tiered sections
<details>
<details>
</details>
</details>
this text toggles when you click on the arrowYou can do multiple levels of this.
this is yet another hidden levelCapitalization
Do not use a “Caps Everywhere” style. It is only used in level one headers and the title metadata. References (visible text) to these page titles (including the navigation) should just capitalize the first letter. Obviously, this does not pertain to words that should always be capitalized according to basic grammar rules (e.g. acronyms, proper nouns).
