Writing Guide (CLI)
Contribution overview
Once you have permission to edit the doc, you can modify any article by choosing the link at the bottom, entitled, “Help improve this document in the forum.” Recognize that what you change will be posted instantly. Check your work carefully before saving your edits!
Style and language
  • Use a spell checker.
  • Resist being overly formal.
Headers
... and so on...
Bold and Italic Text
<strong>Bold Text</strong>
<em>Italic Text</em>
**strong**
Code blocks
maas command do something
  • a command line sequence,
Inline code
Admonishments
Admonishment text.
[/note]
Where:
Admonishment examples
Note Admonishment
[note status="Note"]
key.
[/note]
And it will appear as:
Warning Admonishment
[/note]
And it will appear like this:
Positive Admonishment
[/note]
Negative Admonishment
[/note]
Comments
Occasionally it may be appropriate to include a comment to explain or organize some text. This ends up as an HTML comment – which can be read online, even if only in the browser inspection window – so take it seriously:
[visible text](URL)
Images
<a href="https://discourse.maas.io/uploads/default/original/1X/1f2e6cf2879e391e7ae1ad537cc9ce1baa119f86.png" target = "_blank"><img src="https://discourse.maas.io/uploads/default/original/1X/1f2e6cf2879e391e7ae1ad537cc9ce1baa119f86.png"></a>
Tiered sections
<details>
<details>
</details>
</details>
Capitalization
Do not use a “Caps Everywhere” style. It is only used in level one headers and the title metadata. References (visible text) to these page titles (including the navigation) should just capitalize the first letter. Obviously, this does not pertain to words that should always be capitalized according to basic grammar rules (e.g. acronyms, proper nouns).
