What's new in MAAS (snap/3.0/CLI)
2.7 2.8 2.9 3.0
MAAS 3.0 BETA release notes
We are happy to announce that MAAS 3.0 Beta 2 has been released. This release provides a new feature, along with critical bug fixes.
The Beta can be installed fresh (recommended) with:
sudo snap install --channel=3.0/beta maas
At this point, you may proceed with a normal installation.
NOTE that this is currently a BETA release, so there will be bugs, instabilities, and missing or incomplete features. As such, we invite you to thoroughly test this release and provide feedback. Please remember to file bugs as you find them, and please feel free to interact with the developers on discourse.
Significant changes
With the advent of MAAS 3.0, we are removing support for RSD pods. Registered pods and their machines will be removed by MAAS upon upgrading to MAAS 3.0.
New feature in MAAS 3.0 Beta 2
When deploying a machine through the API, it’s now possible to specify register_vmhost=True to have LXD configured on the machine and registered as a VM host in MAAS (similar to what happens with virsh if install_kvm=True is provided).
New features in MAAS 3.0 Beta 1
  1. PCI and USB devices are now modelled in MAAS
  2. IBM Z DPM partition support
  3. Proxmox support
  4. LXD projects support
  5. PCI and USB device tabs in machine details
  6. Workload annotations
  7. Fixed status bar
MAAS 3.0 models all PCI and USB devices detected during commissioning:
  • Existing machines will have to be recommissioned to have PCI and USB devices modelled
  • PCI and USB devices are shown in the UI and on the API using the node-devices endpoint
  • Node devices may be deleted on the API only
On the API using the allocate operation on the machines endpoint a machine may allocated by a device vendor_id, product_id, vendor_name, product_name, or commissioning_driver.
IBM Z14 and above mainframe partitions are supported in MAAS 3.0. Note that partitions must use HyperV sockets and properly-defined storage groups. IBM Z DPM Partitions can be added as a chassis, which allows you to add all partitions in an HMC at once.
Proxmox support
MAAS 3.0 supports Proxmox as a power driver:
  • Only Proxmox VMs are supported
  • You may authenticate with Proxmox using a username and password or a username and API token
  • If an API token is used, it must be given permission to query, start and stop VMs.
  • Proxmox VMs can be added as a chassis; this allows you to add all VMs in Proxmox at once.
Note that proxmox support has also been back-ported to MAAS 2.9
MAAS 3.0 supports the use of LXD projects:
  • LXD VM hosts registered in MAAS are now tied to a specific LXD project which MAAS uses to manage VMs
  • MAAS doesn’t create or manage machines for VMs in other projects
  • MAAS creates the specified project when the VM host is registered, if it doesn’t exist
  • All existing VMs in the specified project are commissioned on registration
  • Resource usage is reported at both project and global levels
PCI and USB device tabs in UI machine details
Tables for detected PCI and USB devices have been added to the machine details page for MAAS 3.0:
These tables include a new skeleton loading state while node devices are being fetched:
The user is prompted to commission the machine if no devices are detected.
Workload annotations have been added to the machine summary page in MAAS 3.0. These allow you to apply owner_data to a machine and make it visible while the machine is in allocated or deployed state:
This data is cleared once the machine state changes to something other than “allocated” or “deployed.” The machine list can be filtered by these workload annotations. MAAS will warn you on the release page to remind you that workload annotations will be cleared upon releasing the machine.
Fixed status bar
In MAAS 3.0, a fixed status bar has been added to the bottom of the screen, which will always display the MAAS name and version on the left. The right side of the status bar is intended to show contextual data, depending on the UI panel currently displayed. For now, the only data shown is a “last commissioned” timestamp when the user is on a machine details page:
MAAS 3.0 bug fixes
MAAS 3.0 incorporates a large number of bug fixes, summarized in the sections below. Please feel free to validate these fixes at your convenience and give us feedback if anything doesn’t seem to work as presented in the bug request.
One particular bug, #1916860, involves failures in the IPMI cipher suite in MAAS 2.9.2 and up, on the Lenovo x3650 M5 (and others). This particular bug is a not a MAAS bug, but a firmware issue with the subject machines. While the MAAS team can’t fix this (hence the assignment of “Won’t Fix”), the team did provide a easy workaround which helps circumvent this issue.
MAAS 3.0 Beta 2 bug fixes
Here are the bugs that have been Fix Released in MAAS 3.0 Beta 2:
Number Description Importance
#1922107 Hugepages/pinning available for virsh and lack validation High
#1922433 Machine resources path set incorrectly in rackd when using snap High
MAAS 3.0 Beta 1 bug fixes
Here are the bugs that have been Fix Released in MAAS 3.0 Beta 1:
#1896199 API docs link is not offline Critical
#1904245 MAAS Snap fails to build on PPC64 on Launchpad Critical
#1912727 KVM Page Fails to load with error “An unexpected error has occurred, please try refreshing your browser window.” Critical
#1915869 maas snap cli renders SyntaxWarning in the stderr Critical
#1916093 Unable to add more than 3 Promox VMs Critical
#1883824 Support LXD projects in power control High
#1884276 Terrible user experience adding existing LXD host High
#1902425 Failed to allocate the required AUTO IP addresses after 2 retries High
#1908087 Reverse DNS for non-maas RFC1918 zones fails inside maas High
#1908356 Owner data websocket methods are not working High
#1908434 Can’t delete LXD VM in offline state High
#1913323 /MAAS/docs/ leads to 404 page High
#1914588 Enabling debug from snap traceback High
#1915021 Mapping subnet doesn’t work from the MAAS snap High
#1915022 The MAAS snap doesn’t include nmap High
#1915715 LXD VM additional disks all show 10Gb size High
#1915970 Facebook Wedge BMC detection fails on non-x86 architectures High
#1918997 MAAS does not set snap proxy High
#1919000 Unable to connect MAAS to an LXD VM host High
#1887797 Impossible to delete zombie LXD VM Medium
#1894116 Machines can’t be deployed after deselecting all archs in the “Ubuntu extra architectures” package repo Medium
#1897946 hi1620-based ARM Servers are shown as “Unknown model” Medium
#1906212 timeout in testing scripts ignores the days if set to greater than 24 hours Medium
#1911825 Unable to use FQDN as power_address Medium
#1914165 Proxmox does not allow custom port Medium
#1917652 30-maas-01-bmc-config failing on commissioning Cisco UCSC-C220-M4L Medium
#1335175 maas does not combine kernel_opts when nodes have multiple tags with kernel options Low
#1915359 make sampledata can’t find machine-resources Low
#1916844 Removing a machine that is a vm host tells you to remove the “pod” Low
#1920019 maas_remote_syslog_compress is unnecessarily chatty Low
#1887558 Multipath JBOD storage devices are not shown via /dev/mapper but each path as a single device. Wishlist
#1901944 tags field in machine edit page overtakes other fields Undecided
#1909985 Add commission timestamp to machine websocket api Undecided
#1913464 Drop RSD pods UI Undecided
#1914590 Support composing LXD VMs with multiple disks in the UI Undecided
#1915970 Facebook Wedge BMC detection fails on non-x86 architectures Undecided
#1916073 MAAS should install qemu-efi-aarch64 on arm64 KVM pods Undecided
#1916317 UI is using API to request scripts with full content Undecided
#1919381 typo “veryiying” in info message in smartctl-validate Undecided
